what voltage required for electric brakes
Submitted: Monday, May 23, 2011 at 17:46
ThreadID: 86502 Views:14082 Replies:6 FollowUps:5
I have a 16 foot caravan and I dont think the electric brakes are working. I have a Hayman Reece controller. At the trailer plug, I am only getting 3.6 volts at maximum gain. Can anyone tell me if this is enough to activate the brakes?
thanks
Reply By: wjh41 - Monday, May 23, 2011 at 18:30
Hello boboyd,
I am not familiar with the Hayman reece controller but on mine there are 2 voltage adjuster wheels.The main one is set about half way and the other one is used to fine tune the abruptness of the brakes.To test the brakes while stationary jack up one wheel of the caravan and get someone to apply the brakes,the wheel should be hard to turn if not locked up.good luck.
Wally
AnswerID: 455271
Follow Up By: Member - Brian R (WA) - Monday, May 23, 2011 at 18:49
Hi Guys
Wally you have me curious????
Does this test work with a pendulum type brake control???
I was told it was the motion of the towing vehicle that activated the controller
Brian
FollowupID: 728198
Follow Up By: wjh41 - Monday, May 23, 2011 at 19:03
Sorry Brian R I have no experience with the pendulum type,all the ones I have messed with work as above.
Wally
FollowupID: 728199
Follow Up By: snoopyone - Monday, May 23, 2011 at 21:01
You can apply the pendulum type with the manual control.
FollowupID: 728216
Follow Up By: Member - DOZER- Tuesday, May 24, 2011 at 19:12
at full noise, the output voltage should be thesame as battery....most often, the joints between caravan wiring and actual brake wires get corroded at the wheels.
Andrew
FollowupID: 728282
Reply By: Member - Rob D (NSW) - Monday, May 23, 2011 at 21:23
If you put your ear near the wheels of the trailer you should hear a humming sound. I think the brake controller works on a pulse width modulation scheme, so you may not get an accurate reading on a voltmeter set to DC.
If you relax at a faster pace you can get more relaxation in for a given time.
Regards Rob
AnswerID: 455296
Reply By: olcoolone - Monday, May 23, 2011 at 21:51
Brake controllers apply a minimum holding voltage and then the voltage is variable up to around 13 volts.
The voltage increase is set by the deceleration rate of the tow vehicle, sitting stationary you might only be getting 3.6 volts ..... slowing slowly at 100 kp/h may produce 7.5 volts and slowing quickly may give you a voltage of 11.2 volts and slowing very rapidly may give you a voltage of 13 volts.
It's all to do with how much energy is needed to slow a given weight down to the desired speed, the faster the slow down rate the more energy required.
There are other factors and how a brake controller works but I don't want to do what a lot of others on this forum do ....... go into to much detail and confuse the person who asked the question.
You should be able to feel the vehicle speed being retarded when using the hand control only.
I suggest seeing you know little about brakes and controllers I would recommended taking it to a brake specialist.
AnswerID: 455298
Reply By: V8 Troopie - Tuesday, May 24, 2011 at 00:55
Well Bob, you can measure 3.6V or even 12v at the brakes and still have them not working at all.
You see, for the magnet to work at all a current (Amps) has to pass through it. If you had a broken connection, the voltage is still there but no current can flow.
IMO, measuring voltages is very misleading when it comes to electric brakes.
Measure the Amps passing through each magnet ( a clamp on DC amp meter makes that job easy) and you know what's going on.
On my trailer brakes, full on, each magnet requires around 4 Amps. Less Amps, less magnet power, less braking effect. The controller adjusts all that.
Your brakes may have a different magnet but I hope you get the gist how it works.
AnswerID: 455313
Reply By: Puttingdave00 - Tuesday, May 24, 2011 at 10:14
Hi Bob,
Suggest you take the car and van to Puttingdave to check it out for you.
Dave
AnswerID: 455336
Reply By: Michael ( Moss Vale NSW) - Tuesday, May 24, 2011 at 18:27
More than likely, the vans wiring will not be earthed to the vans chassis. The earth will be achieved through the earth pin on the vehicle, so it will be likely a bad earth to the 7 pin plug on the vehicle. It is possible for the controller to be faulty but check the earth on both ends of the vehicle and if that fails, check it again... Also check the wires coming back to the earth from the brakes and the vans earth pin wiring is tight.. check the positive wire to the grakes also. Earth, earth earth,,,,, It usually the problem. Michael
Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.
AnswerID: 455363
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, May 24, 2011 at 18:30
3 volts will not activate the brakes, possibly you can hear the magnets hum if you get close to the drum but you may need a few more volts for you to hear this. Get someone to activate the manual slide on the controller to hear the magnets hum.. I assume you have the max set on the controller Hope this helps. Michael
Patrol 4.2TDi 2003
FollowupID: 728277
