GPS and Digital Map Starter Pack
Submitted: Monday, May 23, 2011 at 07:34
Theresia
Want to turn your laptop into a GPS that will take you anywhere? but.....Does anyone know if the GPS and Digital Map Starter Pack works on a Macbook running Mac OS 10.4.11?
Reply By: mikehzz - Monday, May 23, 2011 at 07:52
Oziexplorer only works on Windows computers., so unless you are running one of the Mac windows emulators or virtual machines then you are out of luck. Cheers Mike.
455194
Reply By: Theresia - Monday, May 23, 2011 at 08:16
Thanks Mike. The downside of owning a Mac. I'm really only after the Topo maps so that I don't have to fight with the paper version as we drive. Theresia
455197
Reply By: Member - nick b - Monday, May 23, 2011 at 09:22
gooday ,you need to have a good look around and dont get suck in with big brand names , do your research ,look on gps forums aswell for what you want
cheers nick
455205
Reply By: Member - Stephen L (Clare SA) - Monday, May 23, 2011 at 14:32
Hi Theresia
Seeing that you will have to buy a few goodies to start you off, eg some form of GPS receiver, Natmaps, OziExplorer or the like, spend a few more dollars and buy when they come on special the 10" Netbooks. I have seen them on special some time for around the $300 mark.
It sounds like you do not like using Windows, but in this way, the Windows computer will work a treat for moving maps. Use it for that very purpose and you will not have to spend a lots of time sorting the Macbook.
Something to think about.
455231
Reply By: Member - Lawrence J - Monday, May 23, 2011 at 17:48
As a long time Mac user and Windoze hater I sympathise with you. I've been down exactly the same road and found no satisfactory solution for the Mac. I've tried running OziExplorer and Garmin Base
Camp using Parallels but the performance is hopeless. So, very reluctantly, I bought a cheap 10" Windoze netbook which I use ONLY for OziExplorer. There is no other software on it than what it came with apart from Ozi and I treat it as a big GPS rather than a computer. It works just fine with a USB GPS aerial. You could use a Bluetooth aerial but I haven't tried this.
Hope this helps.
Lawrence
455268
