Suspension lift for 95 series prado
Submitted: Sunday, May 22, 2011 at 19:46
David W10
Hey all, finally looking at upgrading my standard
suspension for a 2 inch lift for further travel when tackling ruts. Have been recommended bilstein shocks with lovells springs (cost around $1200)
Can anyone tell me their experiences with this setup or recommend a better option for my 95 series prado? Also is heavy duty or medium duty the better option???
Reply By: Allfour4x4 - Sunday, May 22, 2011 at 21:35
Well for what it's worth, we have Bilstein/King on our 95 TD. Put 'em on just after purchase in 2001 and they're still there 170,000k's later, no leaks and all seems fine. Mind you that only includes 3 big trips outback in that time, but yes, we're very happy. To be honest I can't remember what grade springs we used (they were the one's sold by NS4WD in
Sydney...now gone).
I've been in a Prado with extra HD springs and it was rough as guts with no give at all....don't do that!
455168
Reply By: Ruffy-Dan - Monday, May 23, 2011 at 07:32
Getting the correct spring rate is more important than the brand you choose.
If you're buying from a reputable dealer then they should be able talk you through choosing the right rate.
Dan
455189
Reply By: ross - Monday, May 23, 2011 at 08:50
There is lots of good
suspension packages out there. I would also consider the Dobinsons.
Heavy duty is for vehicles that will be fully loaded most of the time.
To my knowledge ,Lovells by
the springs from elsewhere and paint them their own colour.
455201
Reply By: andoland - Monday, May 23, 2011 at 12:02
I had Bilstein shocks and King springs on my 95 series. I had extra heavy duty springs to suit the offroad trips we did and this was of course rough when on the bitumen but can't fault either of these products. I had several other iterations of
suspension prior to that and the Kings/Bilsteins were the best.
Having said that, there will be plenty of others out there who have had sucsess with other brands as
I have a new 150 series Prado and have gone for OME all round, mainly because it was the easiest thing for me to get the dealer to fit. Impressions so far are good, we are heading off to the Canning next week so will have a better idea in a months time.
455218
Reply By: Kimba10 - Monday, May 23, 2011 at 15:26
I had OME fitted to both of my previous 95's one petrol one diesel, and getting it fitted to the 120 I just bought, dont go heavy duty UNLESS the rear will be loaded fulltime, eg draw system, fridge etc other wise running around town will shake your teeth out and ride like a gocart. I had medium both times and handled been fully loaded with no issues, if towing then maybe some additional airbags may be required. If you have a steel winch bar up front then medium will still be ok, if you have a winch fitted to the bar and running dual batts then heavy duty will be required on front only to keep the nose up and medium to the rear unless at stated above the vehicle will be loaded 24/7.. Never had any issues with the actual
suspension itself, workmanship left a lot to be desired on the first petrol prado, the second time was done by a different store and had issues with other stuff fitted but no the
suspension, also ring around plenty of stores to get the best price. Big difference in handling, braking, load capacity, and extended wheel travel was all pluses for me. The big
bore stuff I would keep away from, they are great for your 80/100/200 series cruisers and patrols but too heavy duty for a prado. Ride in one if you find some one that has the heavy duty then the meduim, you will notice a massive difference in ride comfort. My mate had bilstein shocks with king springs and reckoned it was too hard but I drove it and found it to be pretty much on par with the OME, I thought it was fine. My main reason for OME was warranty if needed when out in the sticks, never needed it but believe there follow up in getting any shocks/struts springs etc to you where ever outback you may be is suppose to be the best ?? That I cant comment on as I never needed to. Regards Steve
455240
Reply By: Member - Jim - Monday, May 23, 2011 at 17:28
David W10
I have had Bilstein and King Springs since my 95 series was 10 days old, and happy with it, my prado has rear drawers fitted and seats removed from about the same time.
Front KTFR58HD and F4-BE5-2450-M1
Rear KTRR59HD and F4-BE5-2451-M1
Spring Numbers First.
Regards,
Jim
455263
Reply By: David W10 - Monday, May 23, 2011 at 21:09
Thanks everyone for your
feedback. Makes the decision a lot easier when I hear from the horses mouth rather than a salesperson pushing their product!
455293
Reply By: Mark Howlett - Monday, May 23, 2011 at 21:31
Similar to above, our Prado has 'medium' duty OME coils and OME shocks which were fine with our
home made drawer system, fridge and recovery gear but when the camper was hitched on...some polyair bags worked
well and when unloaded it gives us a nice ride and we leave the bags at 5psi.
Mark.
455297
