2001 GU Nissan Patrol stud pattern
Submitted: Sunday, May 22, 2011 at 10:18
ThreadID: 86467 Views:5950 Replies:4 FollowUps:5
Anyone know if 2001 GU Nissan Patrol 6 stud wheels will fit a 1998 Troopcarrier 6 stud vehicle? The Troopie currently runs 15" Maxxis and I want to change to 16" split rims/ 8PR.
Reply By: Shaker - Sunday, May 22, 2011 at 10:23
The stud pattern is the same, offset differs.
AnswerID: 455104
Follow Up By: rainbowprof - Sunday, May 22, 2011 at 10:30
Thanks Shaker. Excuse my ignorance- does that mean it'll fit or it'll bolt on but might scrape or what? Would you fit a rim/ wheel like this if it were your vehicle? Do you think it'll only give 1/2" difference in vehicle height? Might I expect slight improvement in fuel economy? I know there are heaps of variables, of course.
FollowupID: 728066
Reply By: blown4by - Sunday, May 22, 2011 at 10:29
Someone on here will probably know off the top of their head. Otherwise measure the PCD (Pitch Circle Diameter) of your stud pattern and look up one of the many mag/steel wheel websites to find out the Patrol PCD. Also check the stud diamter and angle of the chamfer on the Patrol wheels against yours and the offset to make sure the wheels don't scrape on L&R full lock or hang outside your guards (which you can fix with rubber flares up to 75mm are allowed on 4WD's)
AnswerID: 455107
Follow Up By: rainbowprof - Sunday, May 22, 2011 at 10:33
blown4by, good points. My Troopie isn't here with me though (I'm away at work) . Saw something that'll run out on ebay soon with few bids:-)
FollowupID: 728068
Reply By: Gary C1 - Sunday, May 22, 2011 at 10:48
I have a 1990 80 series Landcruiser , a few years back i fitted a set of standard wide rims off a GU to my cruiser. They bolt straight on. Actually Bob Jane told me they wouldn't fit, but i told them to fit them anyway. Ha, and yes no problem. Only thing is, mine is coil springs and Nissan rims are widened inwards.
Troopy is leaf spring ???. But split rims will be ok. Only the wide rims may rub on leaf.
Hope this helped.
AnswerID: 455108
Follow Up By: rainbowprof - Sunday, May 22, 2011 at 10:52
Thanks, Gary C1. Yep, mine is leaf front and back.
FollowupID: 728072
Reply By: kev.h - Tuesday, May 24, 2011 at 17:11
Go to the ROH Wheels web site they have a cross reference chart to show what wheels fit what if they show their wheels are the same for both models you could assume they will fit
Cheers Kev
AnswerID: 455356
Follow Up By: rainbowprof - Tuesday, May 24, 2011 at 17:57
kev.h
That would certainly be a valuable tool but I can't find the cross reference chart to which you refer. Any chance of a link?
Brett
FollowupID: 728274
Follow Up By: kev.h - Friday, May 27, 2011 at 13:45
Hi Brett
Go to the ROH site select the type of wheel (4wd etc) then download the catalogue on the last page is a fitment chart which is colour coded all models with the same colour are interchangeable
Site Link
This is the page
Cheers Kev
FollowupID: 728524
