prado gearbox windup
Submitted: Saturday, May 21, 2011 at 18:39
cliffy46
have a friend with gear windup any ideas on how to
check and fix problem
Reply By: Member - Phil G (SA) - Saturday, May 21, 2011 at 19:22
Has he unlocked the centre diff?
455059
Follow Up By: cliffy46 - Saturday, May 21, 2011 at 19:28
he has a 08 prado and high low lever is stuck and can not move it 4x4 light is not on, not sure if he can drive it safely
727991
Follow Up By: Member - Jerry C (WA) - Saturday, May 21, 2011 at 20:14
Hi Cliffy,
Drive it backwards for 10 to 15 metres, then try the low lever again.
Good luck,
Jerry.
727999
Follow Up By: PradOz - Saturday, May 21, 2011 at 20:26
try either or both:
- if he was driving in a circle before this he needs to drive in the opposite direction
or what i do is:
drive in a straight line in reverse at a quick speed if its safe. usually corrects itself but may need to do it a few times.
check his prado manual its in there
728004
Follow Up By: PradOz - Saturday, May 21, 2011 at 20:30
go to:
www.pradopoint.com
sign up as a member, free and easy to do. then look in the 120 section for an answer or failing finding one ask a new question. they are friendly there just like here, but be aware if you dont search hard enough the mods will let you know and lock your post so you have to look properly.
if you have troubles searching, try google with pradopoint in the search section as
well as what you are looking for
728007
Follow Up By: Member - Phil G (SA) - Saturday, May 21, 2011 at 20:37
Cliffy, thats unusual. If the light is NOT on, that means the centre diff is no longer engaged (the light is independant of the lever mechanism). That suggests it it OK for him to drive it and get his lever mechanism fixed.
728009
Reply By: Member - Barnray (NSW) - Saturday, May 21, 2011 at 20:29
Jack a wheel up and it will free up. Barnray
ps there are other tricks that can be used but more experience is required. R
pps there is no checking, using 4wd on hard surface will create the problem all the time.r
455065
