Old petrol
Submitted: Tuesday, May 17, 2011 at 22:27
Member - MYPRADO
How long can one store petrol for, thanks in advance.
Reply By: SDG - Tuesday, May 17, 2011 at 22:47
After reading some bike forums, the Yanks can't store their petrol over winter. Apparently goes off in those few months. I don't know if their petrolis any different to ours. Can't see why it would be.
454638
Reply By: Member Al (Sunshine Coast) - Tuesday, May 17, 2011 at 23:05
OK in dry storage up to 6 months then some degradation begins. I would not store it for more than 12 months. There are also laws limiting the amount you can store in unlicensed premises.
454640
Reply By: Member - Joe n Mel n kids (FNQ - Tuesday, May 17, 2011 at 23:21
i did find something on the BP web site a few weeks ago about the storage life of petrol >>>>
"As general guideline, fuel stored in sealed containers and under
shelter will be suitable to use for about 12 months. If the container has been opened or stored outdoors, especially in the sun, storage time should be limited to 6 months."
http://www.bp.com.au/products/fuelnews/faq.asp#7
Cheers Joe
454643
Reply By: Neil & Pauline - Wednesday, May 18, 2011 at 03:10
I found a product called Bitron fuel additive that I used on the
farm in motors that only got used occassionally and it stopped all the gumming caused by old fuel.
Now my employment is motor homing I put some in the generator fuel tank in the Winni. Have not used the first tank of fuel in over 3 years and it starts first pop any time I have needed it. There are probably other brands but I stick with the devil I know.
Neil
454650
Reply By: Robin Miller - Wednesday, May 18, 2011 at 07:42
Stored a drum of it once for 10 years , I reckon it was a better investment than my super.
It did loose some of the higher order compounds and would ping a bit, but mixed it over time with fresh fuel and all was good.
454656
Reply By: Bushranger1 - Wednesday, May 18, 2011 at 08:19
Modern fuels "go off" much quicker than they did years ago. In particular the petrol that contains ethanol.
Some years ago I was talking to our local mower repair store & he said a large percentage of his repair work was due to stale fuel gumming up power equipment.
I use a fuel stabilizer called STABIL in all my outdoor power equipment & I never get any engine problems caused by stale fuel any more. It extends the life of the fuel for up to 2 years. There is another brand available called POR-15 that someone mentioned on this site a while ago that I believe is available at outboard motor suppliers.
Stu
454660
Follow Up By: dbish - Wednesday, May 18, 2011 at 10:18
I have petrol thats stored in steel jerrycans some of it 12Yrs old & still works fine & motors dont ping on it. Solong as its a steel container & properly sealed in a cool place it will be fine even with out adatives. Diesel on the other hand even with adatives starts to go off after 12Months after 2Yrs it was as black as.
727545
Follow Up By: trainslux - Wednesday, May 18, 2011 at 12:06
dbish, what happened to your diesel sounds like alge growth.
Diesel will store in a clean moisture free container for many years, and will out last petrol easily.
Your older petrol sounds like it was
well sealed, and not opened during storage, and as said before, older petrol stored longer than what is made now.
Ethanol blends dont store as
well as non ethanol too.
T
727562
Reply By: member - mazcan - Wednesday, May 18, 2011 at 12:09
hi myprado
i have kept petrol in both poly and steel containers for 2yrs and found there to be no deteriation
how ever both where full during that time
but when i have left petrol in a half empy container for long period i have found that it lost its octane and formed an
orange gum on the bottm of container
also had same problem leaving small amounts in small engine tanksneedle valves and
seat tend to gum up as
well so i think air in the container is the factor that allows it to deteriate
barry
454679
Reply By: Batt's - Thursday, May 19, 2011 at 21:34
Go to your local boating
shop & buy some [2 plus 4 fuel conditioner] it's use for long term storage of petrol say winter time and it realy helps to start old boat motors that have trouble statring won't hurt your car
454877
