Trouble opening EO
Submitted: Tuesday, May 17, 2011 at 22:07
ThreadID: 86361 Views:1647 Replies:5 FollowUps:3
Every time I try to get on to this site I get this.
Server Error in '/' Application.
Column 'Altitude' does not belong to table Table.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.ArgumentException: Column 'Altitude' does not belong to table Table.
Source Error:
The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL:
1. Add a "Debug=true" directive at the top of the file that generated the error. Example:
or:
2) Add the following section to the configuration file of your application:
Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode.
Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario.
Stack Trace:
[ArgumentException: Column 'Altitude' does not belong to table Table.]
System.Data.DataRow.GetDataColumn(String columnName) +3449035
System.Data.DataRow.get_Item(String columnName) +17
ITBeyond.Mapping.Place.getPlacefromDataRow(DataRow DR) +1003
ITBeyond.Mapping.Place..ctor(DataRow PlaceDataRow) +314
ASP.members_default_aspx.getPlacesUpdatesSince() +557
ASP.members_default_aspx.Page_Load(Object sender, EventArgs e) +1104
System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +25
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +42
System.Web.UI.Control.OnLoad(EventArgs e) +132
System.Web.UI.Control.LoadRecursive() +66
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2428
Version Information: Microsoft .NET Framework Version:2.0.50727.4211; ASP.NET Version:2.0.50727.4209
If I hit refresh it will load up but it is frustrating very as this is the only site it happens, Anyone else having problems.
Cheers Dave.
GU RULES!!
Reply By: Member - Josh- Tuesday, May 17, 2011 at 22:44
Loads ok for me
Josh
AnswerID: 454637
Follow Up By: Member - Peter R (QLD) - Wednesday, May 18, 2011 at 07:33
Try this next time.
Go Tools/options/Privacy
and click on remove cookies.
Scroll through till you come to EO and then select delete cookies.
Exit out and hit refresh
Pedro
FollowupID: 727530
Reply By: MrBitchi (QLD) - Wednesday, May 18, 2011 at 07:47
G'Day Dave,
I've been having the same problem for a while now. Have deleted the cookie as Peter R suggested and seems to have cured it.
AnswerID: 454657
Reply By: Dave(NSW) - Wednesday, May 18, 2011 at 09:07
Thanks Peter R & John,
That seems to have fixed it.
Cheers Dave.
GU RULES!!
AnswerID: 454663
Reply By: member - mazcan - Wednesday, May 18, 2011 at 11:55
hi dave nsw
that happened to me yesterday so i made a cuppa and ate some of my cookies so to speak lol
all ok now
cheers barry
AnswerID: 454678
Reply By: MrBitchi (QLD) - Thursday, May 19, 2011 at 07:50
Hmmm... Same error this morning...
AnswerID: 454793
Follow Up By: Dave(NSW) - Thursday, May 19, 2011 at 08:29
Yeah John,
I've got the same problem again. Funny it only happens on this site.
GU RULES!!
FollowupID: 727674
Follow Up By: Member - Mark G Gulmarrad - Thursday, May 19, 2011 at 08:40
Dave
must be a PATROL thing ;-)
FollowupID: 727675
