toolbox for jayco eagle
Submitted: Sunday, May 15, 2011 at 21:07
dmacca
Just after some ideas for mounting a toolbox on the draw bar of my jayco eagle,at the moment i have to move my jockey wheel to allow enough space for a toolbox , i've been looking for a fully removable jockey wheel with U brackets to take off and on when required , thinking this will give me room for toolbox. Any ideas PLEASE .
Reply By: snoopyone - Sunday, May 15, 2011 at 22:29
Just remember that A frames arent necessarily built to take additional weight and it will aso increase your ballweight as
454407
Follow Up By: dmacca - Monday, May 16, 2011 at 20:02
Hi thanks for your reply , it's only a small toolbox, i just want to throw a few loose
tools nothing to much. it'll be 300 wide by 1m long 600 deep
727337
Follow Up By: snoopyone - Monday, May 16, 2011 at 20:39
Hmmm I have a 3 drawer toolbox that is about 500 long x250 x250 and I can barely lift it with the"few" tools I have.
Hate to think what you can get in one that size.
727346
Reply By: Member - MUZBRY(Vic) - Sunday, May 15, 2011 at 22:29
Gday
Not knowing where you are makes it hard to recommend a place to go.
Just google "trailer warehouse" . They have all types of jockey wheels .
454408
Follow Up By: dmacca - Monday, May 16, 2011 at 20:03
Cheers MUZBRY , i live in
sydney
727338
Reply By: Begaboy - Monday, May 16, 2011 at 07:43
as others have said - we may need to see pics of the draw bar and pics of the tool box ---
just a little hint not seeing your set up - rather than drilling through your draw bar to mount the tool box - use large u bolts to go through your tool box and around the draw bar - you can get these from a lot of trailer spares
places - or if your crafty you can just buy some booker bar ( threaded bar ) and bend up yourself as required then just cap it off under with a bit of flat bar with 2 holes drilled
BB
454421
Follow Up By: dmacca - Monday, May 16, 2011 at 20:07
Thanks Begaboy that's what i was thinking i wasn't to keen on the idea of drilling into the frame
727340
Reply By: Member -Pinko (NSW) - Monday, May 16, 2011 at 07:52
Hi dmcca
Have a look a www.poly.net.au
This is a
roto moulded job and from the photo it looks good.
454423
Follow Up By: dmacca - Monday, May 16, 2011 at 20:17
Hey thanks for that they look great but just a little wide unfortunately
727342
Reply By: Wheretonext - Monday, May 16, 2011 at 22:25
I dont have a photo but I have seen an aluminium one probably 100 x 500 on an eagle. Like one of the pre-made boxes with a lockable lid but slightly triangular to match the A Frame. Partitioned inside to hold the gas bottle. The little lugs on the A frame where the bed support poles sit were relocated to the front corners of the box and then the poles shortened. Great set up and a good sized box.
454511
Follow Up By: dmacca - Wednesday, May 25, 2011 at 02:50
hey ,i'd like to see a
pic of that , thanks for the info
728307
