Removing Photos From My Profile.
Submitted: Thursday, May 12, 2011 at 21:40
ThreadID: 86249 Views:1612 Replies:1 FollowUps:3
I have tried the Edit My Profile tab but cannot find an avenue to remove photos. Thankyou for your help.
Reply By: Member - Ian G (NSW) - Friday, May 13, 2011 at 11:01
After many unsuccessful attempts, I finally succeeded last night.
Click on My Profile
In the top section you will see your photo with a tiny green box in the bottom right hand corner.
Click on this little green box [select] and it will give you options including delete. When you have deleted this photo & any others, then go to the little bar below the photo where is says upload other images. NOTE your new photo must be below 50kbs or it won't load. You need to reduce the size through another program first before uploading. After loading new image, click on the other bar on the right that says update and all should be good.
Hope you have success.
cheers anne g
AnswerID: 454167
Follow Up By: Member - Ian G (NSW) - Friday, May 13, 2011 at 11:03
Whoops, wasn't a green box, sorry, but a little white box in a green bar.
FollowupID: 727001
Follow Up By: Farmboywa - Friday, May 13, 2011 at 12:49
G'day Ian G, thanks for your reply, however it seems I had loaded the photos onto a forum gallery and not My Profile. I finally contacted ExplorOz administration to sort it out for me.
FollowupID: 727013
Follow Up By: ExplorOz - David & Michelle - Friday, May 13, 2011 at 13:35
Ian, You do not have to resize the images down to 50kb this is an older specification. It will take anything but the smaller the better/faster it will load.
Thanks for helping this other member out.
David
Currently Mapping in the Field Across Australia Fulltime in 2024 - 2025
FollowupID: 727019
