200 Series Toyota tires
I want to fit BF Goodrich all terrain tyres to my vehicle but can not find the same size tyres. My current size that are fitted are 245x 75R17Can any one give me some advise on what size they have fitted.
Any help would be appreciated.
Garry
Reply By: snoopyone - Thursday, May 12, 2011 at 21:03
You could play here and see what is similar
245 seems pretty narrow on a 200 as the 100's have 275 x 70 x 16 on them
http://www.rimsntires.com/specs.jsp
275 x70 x 17 is 18mm bigger and will make a difference to your speedo that
at 96.6kph you will actually be doing 98.9kph
AnswerID: 454116
Follow Up By: Sea Star - Thursday, May 12, 2011 at 21:34
Thank you for your reply .I went and checked the size, my mistake it has 285/65R17.thank you again.
Garry
FollowupID: 726964
Follow Up By: snoopyone - Thursday, May 12, 2011 at 21:43
Same applies so unless someone knows of an LT tyre in that size I would think you may have to go to the 275 or 285 x 70 A/T
FollowupID: 726966
Reply By: Member - Alan H (QLD) - Friday, May 13, 2011 at 00:33
replacement tyres
Try the above link for the information you require
AnswerID: 454131
Reply By: Member - Boobook - Friday, May 13, 2011 at 05:58
The best repleacement size is 275/70 17. It is the same diameter and almost the same width as the original tyres.
The BFG All terrain in that size is not suitable, or wasn't last time I looked, as it's load rating is too low. I went with Mickey Thomsons which have been ok.
AnswerID: 454136
Follow Up By: snoopyone - Friday, May 13, 2011 at 09:44
275 x70 x 17 is 16mm bigger and will make a difference to your speedo that
at 96.6kph you will actually be doing 98.5kph
it is 10 mm narrower
Go to the link I provided and put the two sizes in and it will show you all the differences
FollowupID: 726990
Follow Up By: Member - Boobook - Monday, May 16, 2011 at 06:18
Thanks Snoopyone, my bad. I meant 265/70 17.
Also the Mickey Thompson AT is exactly the same overall width as the OE 285. The tread is a little narrower though.
FollowupID: 727244
Reply By: Kimba10 - Friday, May 13, 2011 at 12:22
Make sure what ever you get is no bigger then 15mm rolling diameter, it will be ilegal. Im am in the process of tyring to fit muddies to my prado 120 series. Standard size is 265/65/17, there is no 65 profile muddie available by anyone, if I go to a BF muddie the size is 265/70/17, it puts my rolling diameter out by 28 mm, 13 more then allowed by RTA, which as the bloke from the rta put to me, if I hit some one and kill them I could be in the poop big time, no green slip coverage, and also NRMA can void my insurance as well if I need to claim. Just rang around some engineers and the average price to get a certificate to go the bigger size is $500 just to run a slightly bigger profile which Im not paying so looks like I will have to stick to A/T's which BF do in the a 65 profile size. Spoke to the RTA in regards to who would be in trouble if these places are fitting over size tyres to 4wd's (remeber Im only talking a prado) and he said the owner of the vehicle. Cant believe that majority of us would just ask for mud tyres to be fitted to a standard size factory rim drive out thinking nothing of it and could be in some serious trouble if some thing went wrong. Regards Steve
AnswerID: 454172
Follow Up By: andoland - Friday, May 13, 2011 at 15:40
The potential consequences of the larger tyre size needs to be put into perspective. In reality the circumstances you would be left without insurance, etc, is if it can be shown that the larger tyre size contributed to the accident.
It will still be illegal, such that if the police or transport dept pull you over your vehicle will not be roadworthy, but this is different to having your insurance mull and void.
BTW I am not advocating to go one way or the other, just putting some perspecting into the argument.
FollowupID: 727029
Follow Up By: Kimba10 - Friday, May 13, 2011 at 18:41
I know where your coming from and seems extremely crazy to me that I need an engineers certificate to prove that a slightly bigger profile would be fine, BUT Im not running any chances when it comes to insurance or the fact if i hit and killed some one that i could be sent to an early grave. Wether it can be proven or not if the fact bigger tyres contributed to the accident it was put to me plain and simple today by the RTA and NRMA if they are over size (over legal limit) then my vehicle shouldnt have been on the road in the first place without been engineered. I am not paying $500 for them to fill out a bit of paper and do a brake test and hand brake test to tell me it will be ok which is what I was told today by another engineer. There must be thousands of prados alone running around with 70 profile thinking they are legal. Probably years ago i wouldnt have worried but these days you know what its like everybody wanting to sue everybody for what ever they can....Regards Steve
FollowupID: 727045
Reply By: carlsp - Saturday, May 14, 2011 at 06:48
Origional tyre width on a 200 series is 285 and my understanding is that it is illegal to fit a narrower tyre.
AnswerID: 454220
Follow Up By: snoopyone - Saturday, May 14, 2011 at 08:58
Easiest way to check is for him to read the tyre placard on the vehicle
Usually give alternatives
FollowupID: 727066
Follow Up By: Member - Boobook - Monday, May 16, 2011 at 11:46
There are other options down to 245 width (from memory) in the manual.
The placard says something like as specified on the placard or in the manual.
FollowupID: 727276
Reply By: Sea Star - Sunday, May 15, 2011 at 21:20
Thank you to all that contributed.The information was much appreciated.
Garry
AnswerID: 454401
