Towing a caravan
Submitted: Tuesday, May 10, 2011 at 12:06
ThreadID: 86187 Views:7728 Replies:10 FollowUps:17
I would be interested to find out the different views people have in relation to what gear a caravan should be towed in. I presently have a 18foot Bushtracker
which I tow with a 79 Series Turbo Cruiser with a performance chip and intercooler. I have been told by diffent people that I should tow in fourth gear and not 5th. Is this correct and if so why. I might add that it does tow it well in fifth gear. Would I be damaging the gearbox by towing in 5th.
Reply By: snoopyone - Tuesday, May 10, 2011 at 12:39
Yes you would especially if its an auto.
Do a search on here about "towing in 5th gear"
Also discussed very much on the C & M forum.
Towing in 5th gear
AnswerID: 453841
Follow Up By: snoopyone - Tuesday, May 10, 2011 at 13:52
Here is the reply I posted there
Okay here goes
I tow a 2800kg van with a TD 100ser croozer.
At 90 kph on a flat road the engine is doing 1800 rpm in 5th gear and is below optimum torque range and the Exhaust temp goes up to 400 deg+ as the engine is lugging and working harder to maintain speed.
Before anyone says Well just kick it down.
Well on a light throttle it will just stay in 5th and lug
In 4th gear it is at 2400rpm which is right in the sweet spot and the exhaust temp hardly gets above 325-350deg.
Thats enough convincing for me I always tow in 4th
It also makes no appreciable difference to fuel consumption.
Leaving it the same gear also reduces wear on components in the auto as well.
I would also be reluctant to tow any van at over 100kph as tyres can
give you a sudden sharp shock especially on a single axle setup.
Thats my take on things you can take it or leave but it works for me and has for 50,000k
FollowupID: 726657
Follow Up By: Member - Leigh (Vic) - Tuesday, May 10, 2011 at 14:07
Snoopy one, your are right on the money!
FollowupID: 726658
Follow Up By: wato35 - Tuesday, May 10, 2011 at 14:08
Hi Grant
I totally agree with snoopyone. Its not worth using 5th gear when towing.
FollowupID: 726659
Follow Up By: Motherhen - Tuesday, May 10, 2011 at 14:56
Can i say that again? It is not worth the risk towing in 5th gear (or overdrive in an auto). They are not towing gears.
FollowupID: 726661
Follow Up By: Member - DAZA (QLD) - Tuesday, May 10, 2011 at 16:28
Yes switch off the O/Drive or tow in 4th gear.
FollowupID: 726673
Follow Up By: Grant W - Tuesday, May 10, 2011 at 22:19
Thankyou for your view on this topic. Your reply sounds logical and I think I will stick with 4th gear for towing
FollowupID: 726737
Reply By: Gone Bush (WA) - Tuesday, May 10, 2011 at 14:56
Grant,
I used to have a current model landcruiser TDV8 Trayback. It has the same manual gearbox from the 100 series wagon.
I conducted several tests towing in 4th and 5th gear. Using my scangauge it proved to me that towing in 4th was more economical. Toyota recommend towing in 4th with that box. Fifth gear is actually an add-on from times past and is subject to failure if used to tow with. Too much stress on an isolated cog.
Tow in 4th, your doing your vehicle and your wallet a favour.
AnswerID: 453848
Follow Up By: Grant W - Tuesday, May 10, 2011 at 22:26
I will stick to 4th gear as it seams to be the same view of everyone else. Thankyou for your input.
FollowupID: 726738
Reply By: Member - Captain (WA) - Tuesday, May 10, 2011 at 15:21
Hi Grant,
I agree about the towing in 4th gear, apart from the gearbox reasons given you will also see a drop in EGT's in 4th compared to 5th.
As you have a chip, it can give temps up to 50C higher compared to without the chip for the same speed/gear. I recently found this out when I fitted an EGT guage to my 200 and compared temps with the chip on/off in different gears.
Captain
AnswerID: 453849
Reply By: Member - Kevin S (QLD) - Tuesday, May 10, 2011 at 16:07
This is a serious question. All those Landcruisers towing big Jayco vans that pass me and make me feel as though I am parked when doing 90. What gear are they in?
Kevin
Kevin
2019 Mitsubishi Cross
AnswerID: 453851
Follow Up By: snoopyone - Tuesday, May 10, 2011 at 16:22
They're Jaycos so they arent that heavy.
Some never learn no matter what you tell them.
Go up to 100k and watch the fuel gauge go back rapidly
A guy near where I lived had a big Coromal. Tows it with a Patrol.
The front wheels are nearly off the ground but he doesnt need a WDH so he reckons.
FollowupID: 726671
Follow Up By: Member - Bruce C (NSW) - Tuesday, May 10, 2011 at 17:33
You know what they say Snoopy, "When you argue with a fool then there are two fools.
Or
No matter what intelligent advice you give to an idiot they will always beat you into submission with their stupidity.
Cheers, Bruce.
FollowupID: 726679
Reply By: Baz&Pud (Tassie) - Tuesday, May 10, 2011 at 16:31
Grant,
We have a V8 manual cruiser, and i used to tow in fifth until talking to a mechanic one day about this very subject, he described it to me this way.
When in fourth gear the cog is the size of an apple, the fifth gear cog is the size of a pea, and it wont take the load.
Well, it will take the load till it breaks, then its a matter of how many dollars to fix the problem.
Stay on fourth.
Baz
AnswerID: 453853
Reply By: Member - Bruce C (NSW) - Tuesday, May 10, 2011 at 17:38
Hi Grant,
I can only agree with everybody else above re 4th gear. I does not matter whether you are talking about a manual gearbox or an auto.
But my advice is to try the fuel consumption test for yourself in 5th then 4th just so that you will be convinced as we are of its correctness.
Cheers, Bruce.
AnswerID: 453865
Follow Up By: Member - Bill B1 (NSW) - Tuesday, May 10, 2011 at 19:53
OK, thats the argument for 5th in a manual box.
What about an auto and specifically a Prado that has a torque converter that locks in at 82 kmh and runs at 1800 rpm and then will go to 2000 rpm at 90 kmh.
Once the rpm gets to about 1700 or a steep hill it kicks down and runs at 2300 rpm.
Do Prado people tow in 3rd gear on that basis?
Isn't that what an auto box is for, to select the appropriate gear with the option of an over-ride for really steep hills or a headwind?
Bill
Bill B
FollowupID: 726705
Follow Up By: Gone Bush (WA) - Tuesday, May 10, 2011 at 20:43
Bill,
Toyota's 200 series has a 6 speed auto. They recommend towing in S5 (manual mode, 5th gear). I wouldn't be surprised if there's a similar recommendation in the Prado handbook.
FollowupID: 726719
Follow Up By: Member - Toyocrusa (NSW) - Tuesday, May 10, 2011 at 20:43
Hi Bill. My 120 Prado auto tows a 2.5 tonne Jayco in 4th. I never notice the lock up dropping out on hills. It just seems to drop straight back into 3rd and on the bigger hills even 2nd. If I anticipate the hill is long or steep I will actually pull it back to 3rd around the bottom of the hill. It is a petrol so not sure about the diesel. Cheers,Bob
FollowupID: 726720
Reply By: Member - Vern - Tuesday, May 10, 2011 at 20:46
Hi all
This is a great subject. i have a 6 speed pathfinder and tow a Maytow van weighing around 2.9 tonne loaded. We seem to tow fine at 90kph in sixth how ever it appears that I maybe doing more harm than good. So should I be towing in 5th ???
AnswerID: 453895
Follow Up By: snoopyone - Tuesday, May 10, 2011 at 21:00
Yes
FollowupID: 726722
Reply By: snoopyone - Tuesday, May 10, 2011 at 21:04
TO BillB1
Even more so in an auto.
Read my post at the top I forgot to say its an auto and all that I wrote applies to it
Even on a fairly flat road it hunts in and out on a light throttle and as soon as it drops into top gear the temp goes up by almost 100 deg.
If you havent got an EGT you wont know but believe me when you have one you drive according to it.
AnswerID: 453898
Follow Up By: Member - Captain (WA) - Tuesday, May 10, 2011 at 23:50
Hi Snoopyone,
I agree that a manual is better in the 1:1 gear (4th generally, but may be 5th in a 6th speed), but I am not too sure if that matters in an a late model auto? Generally the auto gearboxes have their own ECU and adjust the gear according to the load.
Also I agree that EGT's are higher in an overdrive gear, but thats to be expected. You roughly put in the same amount of fuel for the load but when you go down a gear you put in more air. As a diesel EGT is simplistically fuel/air ratio, the EGT is always going to be lower in a lower gear for the same speed/load.
As long as the EGT is not excessive, does it matter if its ~50C higher? I haven't seen a 100C difference, 50C is about the max difference I have seen, but I am sure different vehicle EGT's behave in different ways.
Captain
FollowupID: 726739
Follow Up By: snoopyone - Wednesday, May 11, 2011 at 11:26
Well Im sure it does as on a slightly undulating road my auto would hop in and out of O/D all the time so I now leave it in 4th and it sits there happy as all day.
Why wear out the box simply because you can
Yes they do adjust to the load as all autos do Thats why they hop up and down as the load increases and decreases.
Put it in a lower gear and it doesnt do that as the gear can take the undulations.
MY EGT sits between 300- 325 in 4th at 90kph Drop it into 5th and its straight up over 400 every time.
Hottest Ive had it was 512deg on a long hill on a hot day.
Had to drop it into 3rd and slow down before it got tooooo hot.
Also got up around that going from Batemans Bay to Canberra on a cold wet day.
So its 4th for me everyone else can please themselves.
FollowupID: 726747
Reply By: SDG - Wednesday, May 11, 2011 at 00:54
Does this really only apply to the heavier van? Was wondering if the soft floor camper I have, which is really only a box trailer with a tent, is heavy enough to warrant the lower gear. 750gvm, but I have never weighed it loaded with gear.
I also drive a 2.8td Patrol.
Thanks for the reply.
AnswerID: 453917
Follow Up By: snoopyone - Wednesday, May 11, 2011 at 11:19
Best weigh it may give you a surprise and be illegal.
Probably wont affect you towing if thats all it weighs.
FollowupID: 726746
Reply By: friar - Wednesday, May 11, 2011 at 15:45
Hello All, when I towed my camper trailer, about 800kg loaded, my D4D Prado would be forever changing up & down at 100kys, drive in 4th or be a little bit nauty & sit on 110 plus & it stayes in 5th & does it with ease. Friar.
AnswerID: 453963
Follow Up By: snoopyone - Wednesday, May 11, 2011 at 16:59
Probably can in a Prado with 180 litre tank
I would get far if I tried that as I only get 5.7kpl at 90kh in a TD Croozer
I went to see the country not see how far I could get in a day LOL
FollowupID: 726778
