Advice on the Toyota D4D Hilux
Submitted: Monday, May 09, 2011 at 19:59
oztours
Hi Guys,
being nearly there on our search for a new 4WD dual cab there is one last thing eating away at me... The what seems to be common Injector related issues associated with the D4D diesel engines.
What I would like to know, from the D4D owners out there is how wide spread are the problems and is there a Fix?
Is it just a matter of ensuring your diesel is clean and keeping the engine oil fresh?
Any help on this matter would be great, this is the last factor between us and a D4D hilux.
Shaun and Sarah
Reply By: AlbyNSW - Monday, May 09, 2011 at 21:39
Some people experienced the cold rattles with their Hiluxes, my injectors were replaced under warranty. The later injectors seem to sort the problem but it was only some vehicles that were affected
Have a look over on www.Newhilux.net and you will get all the info you need on the subject.
453779
Reply By: Hilux fan - Tuesday, May 10, 2011 at 11:59
Are you buying a new vehicle or second hand? If second hand,
check to see if the injectors have been done. New vehicles should have the issue sorted by now. I purchased a second hand Hilux last year with 170,000 km on the odo and have had no rattle issues, except on really cold mornings for about 30 seconds of driving. With any diesel, you need to put quality fuel into it and keep the
services up to date.
453839
Reply By: p_marns - Tuesday, May 10, 2011 at 22:11
hey there, i have an 07 hilux and it does get the cold rattles first thing in the morning but it only lasts about 2 minutes and it has 145,000k on it and never put a spanner to it . just change the oil regurlar.
453905
