NSW to QLD vehicle inspection
Submitted: Tuesday, May 03, 2011 at 20:05
ThreadID: 86057 Views:4161 Replies:9 FollowUps:6
I've just have a rego check today intending to transfer rego from NSW to QLD on a Troopie 1HZ.
Mechanic wants 3 engineering plates on a simple turbo installation. 2 Stratos seats that replaced std drivers and passenger twin seat. and non-standard steering wheel.
All mods where done in Sydney ARB over last 3 years.
Did I make a mistake at time of fitment to not get plates or is this QLD mechanic taking me for a ride?
Eric
Reply By: Lex M (Brisbane) - Tuesday, May 03, 2011 at 20:10
Don't know about NSW regs but those things certainly require blue plates (enginerring approvals) in Queensland.
Welcome to the Smart State.
AnswerID: 453199
Reply By: Member - Chris & Debbie (QLD) - Tuesday, May 03, 2011 at 20:20
Hi Eric,
You should only need one blue mod plate fitted for these mod's as several codes can be added to a plate. You dont have a long range tank fitted you? would need that done as well.
Chris
Coddiwomple (v.) To travel purposefully towards a vague destination.
AnswerID: 453201
Reply By: Member - Tezza Qld - Tuesday, May 03, 2011 at 20:21
Hi Eric
I agree with Lex All those modifications require a blue mod plate in QLD
No big drama. Plenty of mobile blokes do this work. You should be able to do a deal getting three together. They usually cost about $ 90-00 each.
Cheers Teza
AnswerID: 453202
Reply By: Member - Chris & Debbie (QLD) - Tuesday, May 03, 2011 at 20:22
Hi Eric,
You should only need one blue plate fitted for these mod's as several codes can be added to a plate. You dont have a long range tank fitted you? would need that done as well.
Chris
AnswerID: 453203
Follow Up By: epagets - Tuesday, May 03, 2011 at 21:35
No long range tank thank goodness.
Thanks for all the replies
I wonder how my vehicle got through its yearly NSW inspection?
Eric
FollowupID: 725982
Follow Up By: garrycol - Wednesday, May 04, 2011 at 12:29
I doubt that those mods would have required engineering in NSW.
FollowupID: 726023
Follow Up By: Graham & Lynne - Wednesday, May 04, 2011 at 19:48
If you transfer vehicle from QLD you will need engineer certificate for the non factory turbo and the seat, steering wheel will be ok the reason you have not needed it already is because the vehicle was already registered in NSW when modifications where done. Thanks Graham
FollowupID: 726080
Reply By: Member - Andrew L (QLD) - Tuesday, May 03, 2011 at 20:24
It's not an engineering feat or examination you require, it merely a modification plate for any changes you have done that are not the manufacturers or not complying to the ADR's for the vehicle.
There are many available mechaniclaltrade related people/businesses with the expertise and approval to issue you with a "blue' modification plate for your respective modifications made to your troopy.
They are not expensive, usually under $100 or a bit above, possibly depnenant on the modification and time required to ensure its compliance, suitability and safety.
As much as it might seem a pain for a southerner, just remember, you won't have to do another inspection process in it's life until you resell the vehicle..or let the rego lapse and have to re register it.....how dumb is that...lol..
Have a look here for some info on the process..and go visit the qlddtmr website.
http://www.qldstreetscene.com/forums/topic/555-modification-plates/
QLD Mod Quide Handbook
http://www.transport.qld.gov.au/qt/LTASinf...ion_Jan05v2.pdf
QLD Mod Application Form (the application form to get a blue mod plate)
http://www.transport.qld.gov.au/qt/formsda...LE/F1854_es.pdf
QLD Vehicle Code of Practice (Guide to Approved Inspection Stations (AIS) and how to go about getting mod plates. Also contains a list of the codes and what their for)
http://www.transport.qld.gov.au/qt/LTASinf..._codeofpractice
AnswerID: 453204
Follow Up By: Member - Joe n Mel n kids (FNQ - Tuesday, May 03, 2011 at 22:51
it may be my computer but the links did not work ....
Joe
FollowupID: 726000
Reply By: Member - Joe n Mel n kids (FNQ - Tuesday, May 03, 2011 at 22:49
Why would the turbo need one, i am only curious as i intend to fit a turbo ????
Joe
AnswerID: 453224
Follow Up By: Member - Chris & Debbie (QLD) - Wednesday, May 04, 2011 at 16:43
Hi Joe, you require a modification plate as the vehicle has been altered from standard, but not enough to require an engineers certificate.
It is no major drama, you can do the mods yourself then just take the vehicle to be inspected and the plate added.
After I fitted the turbo, intercooler and long range tank to my 80 series, I took it to ARB who looked it over, stamped and fitted the mod plate. ARB also sent the paperwork to Dept of Transport, cost around $80.
FollowupID: 726051
Reply By: Member - Bucky - Wednesday, May 04, 2011 at 05:58
If ARB has done all the work, then they should all the paperwork.
It should just be a piece of paper, to get your "blue plates".
After all, all those bits added have been engineered, and fitment has been done by qualified people..
Also would have thought that the yearly roadworthy needed to attain your NSW Rego, would have noted the modifications, with certificates.
Bucky
AnswerID: 453232
Reply By: Member - DAZA (QLD) - Wednesday, May 04, 2011 at 10:44
Why not contact a Qld ARB outlet, they might do one for you??.
AnswerID: 453251
Reply By: Member - Boo Boo (NSW) - Wednesday, May 04, 2011 at 20:56
epagets
I really feel sorry for you.
I transfered my rego from NSW to NT for 15 months then when I got back to NSW I had to get a blue slip for the troopy.
Thats when the trouble started. They would not pass the troopy because it had an after market turbo and Turboglide did not have a certificate to give because for them to get certified it would cost too much they recommended that I take the turbo off, get it registered, then put the turbo back on.
Thats exactly what I ended up doing as the cost to do the exhaust tests etc would have been about $2500.
I got it reinstalled the day after I got it registered.
AnswerID: 453299
Follow Up By: epagets - Saturday, May 07, 2011 at 11:35
Well I got the inspection done. Provided the mechanic with the reciepts for the work,.
And he charged me $75 ea for turbo and seats.
Mark Weber got a lot of flack about his Nanny state comment last year. But he's dead right.
Thanks for all the help.
FollowupID: 726325
