Winter storage of battery
Submitted: Tuesday, May 03, 2011 at 16:05
ThreadID: 86048 Views:1808 Replies:6 FollowUps:5
Today I was reading an article on storing the van for winter.
It recommends disconnecting the battery as it will last longer.
At present I have it charging for a couple of hours (on a timer) each day and the charger indicates float/full charge.
What do others do when the van is going to stand for a long period???
Thanks guys
Brian
Reply By: Member - Phil G (SA) - Tuesday, May 03, 2011 at 16:11
I have one of those rotary switches on the earth terminal, and switch it off when it goes in the shed. I still put it on the charger every 4-6 weeks.
AnswerID: 453161
Follow Up By: Member - Phil G (SA) - Tuesday, May 03, 2011 at 16:15
Looks like this:
FollowupID: 725924
Follow Up By: Member -Toonfish - Friday, May 06, 2011 at 22:12
the screw on/off isolators are a good thing but i have seen more than my share break as they appear to be mase of some metal plastic composite material ,both times they were promptly replace but still mad of the same materials, have a close look at them youll soon see .
smaller marine type stiching isolators arent that much dearer .
2013/14 around oz adventure bound
FollowupID: 726279
Reply By: Member Al (Sunshine Coast) - Tuesday, May 03, 2011 at 16:17
Hi Brian, Disconnecting is not a bad idea. It ensures that there is not some unrecognised load and is protection against faults.
Then either leave it permanently connected to a multi-stage charger with float function or give it a few hours charge once a month.
Left alone to discharge is death to a lead-acid battery.
AnswerID: 453162
Reply By: mike39 - Tuesday, May 03, 2011 at 17:02
I do exactly as you Brian.
In this case not the van but three vehicles left at home, batteries connected (for clocks etc.) and a 24hr. timer with a charger at each battery.
2.5a. chargers, timed for 2hrs/day.
Come home and all systems ready to go.
mike
AnswerID: 453171
Reply By: Peter_n_Margaret - Tuesday, May 03, 2011 at 18:31
I do nothing.
My solar panels and regulator just take care of it.
OKA196 Motorhome
AnswerID: 453181
Follow Up By: member - mazcan - Tuesday, May 03, 2011 at 22:32
hi brian r wa
i use my solar panel and its regulator to take care of my camper deep cycle all year round and never had any problems so easy for nearly 4 yrs
dont have to worry about power failures either or switches etc
barry
FollowupID: 725996
Follow Up By: member - mazcan - Tuesday, May 03, 2011 at 22:34
hi
ps leave everything connected but switched off in camper
FollowupID: 725997
Reply By: MEMBER - Darian, SA - Tuesday, May 03, 2011 at 18:59
My 3 van batteries all stay connected when it's at home but I turn the 240V charger on a few times a week (if convenient) - I have a small solar panel permanently connected too (the van cover blocks the main ones out) - overall, I've taken the advice that batteries should be full as a goog all the time, for a longer life.
AnswerID: 453186
Reply By: Member - Bruce C (NSW) - Tuesday, May 03, 2011 at 19:51
Hi Brian,
I disconnect my batteries from the van circuit and switch to shore power (240 feed from shed). I have AGM batteries.
I then top the batteries up with a multi stage charger about once each month.
Flooded cell batteries lose about 4% of their charge per week. (car batteries)
AGM batteries lose about 4% per month. According to the information I have read.
Keep them, quote, "full as a goog" and you can't go wrong.
Cheers, Bruce.
AnswerID: 453195
Follow Up By: Member - Brian R (WA) - Tuesday, May 03, 2011 at 23:22
OK
thanks guys , it is a deep cell, and that's about all I know.
Thinking I will crawl in my little A'Van which is stored in the shed.
Check if battery should be topped up.....with water ?????
I think, maybe stick to the routine
Brian R
FollowupID: 726001
