4 seasons hatch travelling open or shut?
Submitted: Friday, Apr 29, 2011 at 19:41
ThreadID: 85962 Views:7030 Replies:6 FollowUps:4
New to caravaning....have a 2 of the 4 seasons hatch ....do I travel with them open or rain or shut position?......
am thinking of the wind on the shutters being too much?......but also dust in the 'van......open or part open will they act as a pressure positive to help exclude dust or being in the roof will not have that effect?
I am guessing that if I keep the back hatch fully closed one closed and the more forward open at least the front shutter of that one....it may help pressurise the interior
I will tape up the door vent in dusty conditions
VKS 1341
Reply By: Notso - Friday, Apr 29, 2011 at 19:44
Keep them shut. They aren't that robust.
If you are worried about dust get a pressure hatch fitted.
AnswerID: 452778
Reply By: snoopyone - Friday, Apr 29, 2011 at 21:03
Friend of mine forgot to shut it Cost about $65 for the front section on its own.
Technically it is illegal to tape up the door as if you get a gas leak and you smoke you may burn more than your eyebrows when you open the door.
LOL
AnswerID: 452784
Follow Up By: Member - bungarra (WA) - Friday, Apr 29, 2011 at 22:03
thanks for that............only intend to consider taping the door up under extreme dust conditions.............fridge is not gas.....only stove inside and the bottles would be turned off at the cyclinder in any case.........
VKS 1341
FollowupID: 725486
Follow Up By: Motherhen - Friday, Apr 29, 2011 at 23:04
Hi Bungarra - as said, keep them shut until you stop. Like you, we don't have a gas fridge and gas is always turned off when travelling, however i put a couple of old bathroom flannels attached with Velcro tabs between the door and the screen door and that filters most of the dust without breaching any legalities of the door vents. Also if you have a bathroom put a plug in the shower drain for dusty roads. We have a 10 cm thick piece of sponge which fits into the four season vent which catches any dust coming down through the poor seals on the four seasons.
FollowupID: 725499
Follow Up By: Member - bungarra (WA) - Saturday, Apr 30, 2011 at 08:44
Thanks Motherhen.
excellent tips and make a lot of sense......we are heading out this morning and will do exactly as you have suggested
VKS 1341
FollowupID: 725516
Follow Up By: Member - barry F (NSW) - Saturday, Apr 30, 2011 at 17:47
Thanks Motherhen, now I know why our combo toilet/shower at times gets dusty between destinations!
From now on I to will plug the shower drain hole. Many thanks for the tip & safe travelling.
FollowupID: 725582
Reply By: Member - Dunworkin (WA) - Friday, Apr 29, 2011 at 22:50
Our first van was a Windsor back in 1980, we dragged that van over all the dirt roads through the then Hamersley Ranges, we also dragged it up the Great Northern Hi/way, between Fitzroy Crossing and Halls Creek the road was atrocious, anyone who remembers the road back then will appreciate how bad it was. To keep the dust out we opened up the front section of the 4 seasons vent of the front vent, (we had two, one at the back and one at the front) I remember when we got to Halls creek we pulled into the caravan park to find everyone else pulling out all their stuff, cushions the lot to get rid of the dust. I took one look and told hubby I didn't want to go in the van after seeing what we were looking at. When I did go in there was no dust to be seen, the only problem we had was a couple broken eggs in the fridge. I was so grateful, it was the front vent that had pressurised the van. I will add that it was many years ago and those vans were a lot stronger than they are today. I don't think we would be game to leave the vents open on our current van.
D
Simba, our much missed baby.
AnswerID: 452792
Reply By: Member - res.q.guy (Vic.) - Saturday, Apr 30, 2011 at 08:52
We have two hatches on our roof, the wind is too strong to have the front vent of the front hatch open. We open the front vent of the rear hatch which is behind the a/c unit on the roof, so is protected fron the strong wind conditions.
We have never covered the door vent, and never had any trouble with dust in the van in 10 yrs.
Neil
AnswerID: 452806
Reply By: Member - Bruce C (NSW) - Saturday, Apr 30, 2011 at 09:40
Hi Graeme,
We have 2 - 4 seasons hatches in our van and I don't think they seal all that well so I think there is a small amount of pressurization from the front one. Anyway we don't have much trouble from dust and our road in to our place gets like bull dust sometimes, especially after grading. As the others have said I would leave them closed and the foam as Motherhen suggests is a very good idea.
Still have not heard from the nephew re boat loader. Talk about slack.
Cheers, Bruce.
AnswerID: 452810
Reply By: Member Boroma 604 - Saturday, Apr 30, 2011 at 09:55
Gooday,
Our caravan came with 1 pressure hatch which was too small we had 2 larger ones fitted which work very well but still need to tape the other finned vents for best results.
With the door bought a piece of silver coated foam from Clark Rubber, cut it to size and fit that between main door and screen, keeps dust out and also invaluable for keeping warm in cold climates. Keep it behind dinette bolster when not being used.
Boroma 604.
Image Could Not Be FoundImage Could Not Be Found
AnswerID: 452812
