Canopy Fit Out
I am about to fit out a two door telstra style aluminium canopy. I have done a search for various ideas. I can see weight can add up quickly. I have noted some do without a fridge slide and live with the loss of usable space above needed to open the fridge.
The cube lock method of making a frame for drawers, false floor or for a nest of plastic tubs looks good. Has this proven to be durable or did you need to sikaflex or rivet the joiners. What material did you use for decking and what spacings did you use without the deck sagging. Obviously it depends on the deck loading by I am thinking in general camping travel load terms. A outback two drawer set up that came with the vehicle weighs about 80kgs alone so I am interested in any weight saving build methods at least to see if this weight can be reduced.
The most common idea of kitchen one side and storage the other seems like a good template to follow.
Mine has the water tank in the canopy across the front rather than under the tray where it belongs and a under tray drawer so I need to work around this.
Cheers Peter
