tv antennas travelling
Submitted: Wednesday, Apr 20, 2011 at 19:28
choc
buying a new vw camper set up.
want to know about a tv antenns.1)looking at saturn ommi
2)winnegaurd roadstar rs 2000
has anybody had experience with these units.
Reply By: Faulic_McVitte - Wednesday, Apr 20, 2011 at 21:31
both RS 1 as bad as the other. Omni directional is absolute BS. Technically impossible to make a good omni directional TV aerial. The other issue there is no substitute for element size. You cannot amplify something that is not there. Without decent elements you have nothing to amplify. While Saturn Omni may claim it can do vertical omni directional it cannot be done with their design or any design satisfactorily that would not cost 1,000's of $. If this rubbish worked everybody would have them on their houses. You need to be right on top of the TV transmitter for that rubbish to work.
12V ACTIVE COLOUR ANTENNA UHF/VHF/FM $49.95 is quite reasonable and better than what you have asked about in performance.
One of the best units does vertical and horizontal and cross polarisation is the
DIGIMATCH VHF/UHF Explorer also available from DSE under part no L4024 $69.95. The Explorer is specifically made for the digital channels and because of the technical excellence of the unit out performs aerials larger in size. The design of the aerial elements are covered by patents because of their unique design that makes them so good.
451938
Follow Up By: landseka - Thursday, Apr 21, 2011 at 09:28
Hear hear to the Digimatch. I have had one for years and it is excellent.
It takes up a bit of room when assembled so I travel with it attached to it's telescopic mast. (old swimming
pool net handle).
Cheers Neil
724592
Reply By: Member - Kevin S (QLD) - Thursday, Apr 21, 2011 at 16:23
Does the Digimatch UHF/VHF Explorer require a booster?
Kevin
451998
