DIY Telescopic pole question - sprung buttons?? Do you know what they're called?
Submitted: Wednesday, Apr 20, 2011 at 15:22
geocacher (djcache)
Hi all,
Figured I might as
well ask the like minded folk here who prefer to self manufacture as I do. Someone is bound to have the answer.
I'm making some sliding poles - ie. one bit of square hollow section telescoping into another. I want to use those sprung buttons like you see on some telescopic tent poles, paint roller poles, extendible fishing net handles etc.
I've not cut the handle of my bream net off to have a look but I'm guessing they are a presprung button, possibly just bent spring steel that slide up the pole into position on the inner tube.
Questions:
Does anyone know what they would be called in a hardware search on google or in a hardware/fasteners & fittings catalog?
Even better, does anyone know where to get them & what they are called with that supplier?
Any help appreciated.
Thanks,
Dave
Reply By: Sir Kev & Darkie - Wednesday, Apr 20, 2011 at 16:07
Dave,
I was going to suggest the Tent pole locking nut and T nut
Found here
But just realised you want the push button type :(
Cheers Kev
| Russell Coight:
451890
Reply By: Member - Boo Boo (NSW) - Wednesday, Apr 20, 2011 at 16:32
Dave I don't know what they are called, but I bought some years ago in a
camping store.
I think it may have been Kangaroo City.
451893
Reply By: Member -Dodger - Wednesday, Apr 20, 2011 at 16:37
You could also do what I did and simply get the paint roller extensions that are around 4 ft. Long and extend to approx 7 ft. Then simply fit the spigot into the end.
451895
Follow Up By: Wilko (Parkes NSW) - Wednesday, Apr 20, 2011 at 19:26
I 2nd dodgers advise. I use the telescopic paint roller handles in replacement of the poles on the awning on my Oztent RV5. I gotta paint roller and cut it down so it fits thru the brass gromet. They are solid as.
I also use 1 that can take, a boat hook, a landing net, Gaff, and lure retriever.
Cheers Wilko
724530
Reply By: Mr Pointyhead - Wednesday, Apr 20, 2011 at 16:44
Dril a hole in the outer tube and weld a nut on it. The tighten a screw/bolt through
the nut to tighten on the inner tube to hold in in place.
451896
Reply By: Member - Chris & Debbie (QLD) - Wednesday, Apr 20, 2011 at 16:53
Hi Dave, they are called 'Button Clips' or 'Spring Button Clips', you can usually pick them up at
camping stores. Primus show them on their web site.
Chris
451897
Reply By: geocacher (djcache) - Wednesday, Apr 20, 2011 at 17:33
Hi Chris & Debbie,
Thanks, that's just the reply that I was looking for.
I also appreciate the
well intentioned responses regarding captive nuts, but that's what's being used at the moment and it's not satisfactory. Supporting the floor of a hard floor camper is a big ask for a mild steel screw tip against a flat surface.
Going to closely spaced holes and button clips will give nearly as much flexibility to adjust a range of heights and will guarantee a firm hold at that height.
They aren't even that great on tent poles but given the range of adjustment required on a sliding tent pole it's probably not realistic that there's another solution. I do have several alloy telescoping tent poles that twist to lock & they are heaps better and significantly lighter.
Thanks guys,
Dave
451903
Reply By: Tim - Stratford (VIC) - Wednesday, Apr 20, 2011 at 18:49
Reply By: Member Al (Sunshine Coast) - Wednesday, Apr 20, 2011 at 18:50
Hi Dave, I had need of the same thing a few years ago and made some clips from about 3mm wire. Just plain fence-wire not spring quality. They cost zilch and worked fine for years. The sketch shows the arrangement.
Image Could Not Be Found
451909
Reply By: geocacher (djcache) - Thursday, Apr 21, 2011 at 23:20
Hi all,
Passing through
Geelong today, I picked some up at Rays Outdoors in Ryrie St. They are COI Leisure ones made from wire springs and the button sits on the wire. They look like they'll do the job.
I also got a reply back from
Bell Springs (Thomastown) who I'd emailed before I found the ones at Rays. They had a range of several different sorts on their website.
__________________________________________________________
Thankyou for your enquiry. We sell to everyone.. We accept MasterCard and Visa. We can ship to whereever you are.
10 Off Pear Shape @ $2.50ea plus GST
10 off Single Button V Shape @ 2.25ea plus GST
Both Currently in Stock.
Thought I'd add it here for the archive in case someone's looking in future.
Thanks for your help.
Dave
452030
