govener removal
Submitted: Monday, Apr 18, 2011 at 13:34
ThreadID: 85714 Views:2108 Replies:3 FollowUps:1
I have replaced my tired old td42 diesel (1993 mavrick) with a japanese import td42t. the problem is that the motor will not rev past 2100rpm so I assume that it has a limiter of some sort. any ideas of how to remove or disengage would be most appreciated
thanks
Reply By: Dave(NSW) - Monday, Apr 18, 2011 at 15:30
brian,
You may be able to get some info here http://www.patrol4x4.com/forum/
Cheers Dave..
GU RULES!!
AnswerID: 451668
Reply By: Member - Steve & Cecily W (QLD - Monday, Apr 18, 2011 at 15:30
I don't know but you might receive more info by posting on the Nissan Patrol forum. @ http://www.patrol4x4.com/forum/
Haven't stopped smiling!
AnswerID: 451669
Reply By: howesy - Monday, Apr 18, 2011 at 22:33
there is a TD42T1, TD42T2, TD42T3, TD42T4 and depending which version max power (kw) is developed around 3600 - 4000 revs with torque maxing at 2000revs ao it really should rev to at least 4000 revs one would think.
Some versions had a semi electronic system which retained mechanical njectors so which pump are you using on it, if its one that came with the new engine it may be looking for some electronic input.
Like they said best option is to go to the patrol forum.
AnswerID: 451732
Follow Up By: brian t1 - Saturday, Apr 23, 2011 at 08:50
Thanks for all your help, i decided to check all the filters before I changed over the injector pump and I found that the micro filter in the fuel inlet pipe was clogged. Cleaned it up and refitted to the injector pump. Engine now purrs like a kitten (or roars like a lion) all through the rev range. Once again thanks
FollowupID: 724802
