The power of corrugations
Submitted: Thursday, Apr 14, 2011 at 07:50
Rockape
This photo just about says it all.
Image Could Not Be Found
Have a good one all.
Reply By: snoopyone - Thursday, Apr 14, 2011 at 08:00
Or possibly overloading a span like that.
451206
Follow Up By: Rockape - Thursday, Apr 14, 2011 at 08:22
That load is fine, being poly pipe it is quite a light load.
723816
Follow Up By: Baz&Pud (Tassie) - Thursday, Apr 14, 2011 at 08:58
Thanks in anticipation.
Which road is it?? going by the name on the door would say it's the GRR.
Baz
723824
Follow Up By: snoopyone - Thursday, Apr 14, 2011 at 09:50
Admittedly 1 pipe would be light but a load like that would be reasonably heavy and the amount of harmonic flex over corrugations would increase the weight in the centre of the trailer I would have thought.
It was posted here some time ago that a toolbox on a vans rear bar could put up to 7 times its own weight on the bar when bouncing up and down on rough roads so presumably the same would apply here.
Perhaps a couple of extra straps to keep it stiffer MAY have helped.
Wouldnt like to have to ring the boss and tell him no matter what the cause LOL
723833
Follow Up By: Member - Tony (ACT) - Thursday, Apr 14, 2011 at 09:50
All it needs is a set of training wheels!
723834
Follow Up By: gidgea jack - Thursday, Apr 14, 2011 at 13:57
check out another photo(on google earth) of same load at tilmouth roadhouse on the tanami road ..might be a bit too much whip in that load to have the trailer extended out so far me thinks..
723858
Follow Up By: snoopyone - Thursday, Apr 14, 2011 at 14:29
Could you post a link to it please
723862
Follow Up By: Rockape - Thursday, Apr 14, 2011 at 15:46
Snoopy,
you just answered your own question, corrugations took their toll on the rig.
Now this is me overloading to the max.
723876
Follow Up By: snoopyone - Thursday, Apr 14, 2011 at 16:17
Yep but you have wheels under the load not half a k between them like the OP.
Anything is likely to buckle with that sort of a span.
If he had a dolly under it further back it may not have happened.
Apart from the corrugations it looks like an illadvised rig for the job in the conditions in which it was expected to work.
723880
Follow Up By: Rockape - Thursday, Apr 14, 2011 at 16:37
Snoopy, Graham or Tom,
Took 3 long loads up the cape that even Toots Holzimer said we would not make it, and I mean long.
Well we did, through some very, very bad corrugations and dips.
Extendables are made to do exactly what is shown in the picture, just the corrugations took their toll.
Enough said.
723883
Follow Up By: skmaint (WA) - Thursday, Apr 14, 2011 at 22:18
Hi Rockape,
That load would be
well over the 30 tonne mark easy. To me the trailer has been extended too far and it does not have the support in the middle. Yes the corrigations would take its toll on that. The forces applied to the middle of the load would be great ( as it has already shown). I suppose you could just put it down as a learning curve. To me it is a great picture but would not like to be in the drivers shoes when he had to ring the boss.
Simon.
723913
Follow Up By: skmaint (WA) - Thursday, Apr 14, 2011 at 22:20
Sorry forgot to add....The trailer would not be overloaded.
Simon.
723914
Follow Up By: Member - Jerry C (WA) - Thursday, Apr 14, 2011 at 23:37
Why is anyone surprised that it sagged? Place a length or a bundle of conduit between two supports, one at each end, in the shed and leave it for a couple of days. Depending on the ambient temperature it will sag and drop to the floor. And that is without any corrugations.
Jerry
723919
Reply By: Wilko (Parkes NSW) - Thursday, Apr 14, 2011 at 08:13
The tails upgrade will have to wait a while now lol.
Cheers Wilko
451209
Follow Up By: Rockape - Thursday, Apr 14, 2011 at 08:21
Wilko,
yep !!!! but at least you can get the load off easily now. They might patent it as the new easy load banana trailer.
723815
Reply By: vk1dx - Thursday, Apr 14, 2011 at 08:50
This is what the corrugation up on
Cape York did to our shock.
It just unscrewed with the shaking. Replaced under waranty as
well!!!
Broken shockAlmost brand new as well.
well!!!
451215
Follow Up By: Member - DickyBeach - Thursday, Apr 14, 2011 at 09:17
Hey Phil,
What sort of vehicle was it and at what speed were you driving?
My 1994 LandCruiser, towing a camper-trailer, experienced zero problems last winter on our trip up to
Cape York, and with the same shocks that were on the car when we did the CSR many years earlier.
Just wondering ....................
723826
Follow Up By: vk1dx - Thursday, Apr 14, 2011 at 09:43
A 100 series 4.2TD LC. It was faulty from the start. Just popped out. We were on the Starcke Track and doing about 40K when it happened. First time problem with the car. Got a temporary replacement up to
Laura Roadhouse the next day. Even fitted it for me. I now carry spare shocks.
Not a problem since. And we have travelled that lovely road to the Bungles and
Mitchell Falls. Mostly at 50. 80 plus on the better roads that are corrugated. The car seems to travel
well at that speed. But we also drop the tyre pressure down a tad.
I would not swap shock absorber brand. I am happy with my choice. They are Bilstein. Very similar to the ones in my sons rally car. Excellent ride. Hardly built up any heat on the above roads. Just an unlucky break. When back
home I called them and it was replaced immediately. I had to send them a photo though. Arrived by overnight parcel express the next morning and in the car before lunch.
723830
Reply By: Member - Kingsley N (SA) - Thursday, Apr 14, 2011 at 10:16
That looks like a truck load of corrugations ready to be installed! (Just being silly).
Kingo
451219
Follow Up By: Rockape - Thursday, Apr 14, 2011 at 11:30
Kingo,
I like the way you think.
Have a good one
723841
Reply By: Gobumpy - Thursday, Apr 14, 2011 at 19:41
By the looks of it its an orix rental traiker too ha ha ha hope they upgraded the insurance.
Ill find out a bit more info shortly about the situation as a family member works for cockburns ha ha.
Scott
451262
Follow Up By: Rockape - Thursday, Apr 14, 2011 at 19:54
Scotty,
good stuff, let us know what happened.
723896
Follow Up By: Gobumpy - Thursday, Apr 14, 2011 at 20:03
Hey mate
From the text i just got it happened about 2 years ago was a bran new trailer maiden voyage, it was not over loaded but police, insurance and company reports said it was stretched to far not glutted properly and bad bad corrugations. Not sure where it happened but feel for the driver if it was hot cause he would have been waiting a while to get it transfered to another trailer. Ill let ya know more when I get more info ha ha
Scott
723897
Follow Up By: Rockape - Friday, Apr 15, 2011 at 06:58
Thanks for that Scott
723925
Reply By: Diesel 'n Dust - Thursday, Apr 14, 2011 at 23:25
Thanks for sharing the photo Rockape.
I had a trailer wheel guard bust on me today. And after a long day trenching for a station we were not pleased. Just made the day even longer. But we prevailed.
The
Marble Bar Nullagine just north of the
Fortescue River is heavily corrugated!!!
It's teeth rattling driving!!
Cheeers
451276
Follow Up By: Rockape - Friday, Apr 15, 2011 at 07:06
Matthew,
I feel for you on those corrugations
Have an easier day today
723926
