Nylon Inserts for Snorkel Mounting Screws??
Submitted: Saturday, Apr 09, 2011 at 19:27
Big Woody
Hi All,
Just wondering if anyone knows where I could find the nylon inserts similar to the ones that are used for the mounting bracket on the "A" pillar for a Safari
Snorkel?
They are the ones where you drill a larger diamter hole, insert the plug, and then put the fixing screw into the plug.
Any help will be gratefully received.
Brett
Reply By: Dust-Devil - Saturday, Apr 09, 2011 at 19:36
B-W
I know what you mean however they are usually an OEM item and about as useful as mammaries on a bovine.
If you are going to be drilling holes, just drill the appropriate size hole and fit a 6mm 'nut-sert' or 'riv-nut'. Both one and the same thing.
DD
450794
Follow Up By: Shaker - Saturday, Apr 09, 2011 at 21:54
Isn't a bovine a cow? In which case mammaries are very useful if you like white coffee!
723328
Follow Up By: Lex M (Brisbane) - Saturday, Apr 09, 2011 at 22:08
I agree with the nutserts.
Mine had the
snorkel fitted when I got it and leaked water into the a pillar and down onto the floor inside because it had square nylon inserts in round holes.
Installed nutserts and had no more problems.
723329
Follow Up By: Dust-Devil - Saturday, Apr 09, 2011 at 22:29
Shaker
Bovine = domestic cattle plus other genus of the Ox family, so your half correct.
It was remiss of me not to delineate the said 'bovine' as Mr Bovine. Promise I won't do it again.
723331
Follow Up By: member - mazcan - Sunday, Apr 10, 2011 at 11:32
hi big woody
i give my vote to the nutserts
they are the greatest invention and i have used them on so many applications i've lost count have also used them in fiberglass and aluminuim as
well subject to material thickness of course
they will--- if inserted properly ---last for ever and with-stand vibrations a lot better than the nylon inserts
i bought my own insert tool and
( its paid for itself i think from memory it was $90 at the time several years ago now due to frequent use)
you will also need a 9mm steel drill bit as its very important that the insert hole is a very neat fit otherwise when you crimp the insert it will turn instead of being tight in the metal etc
cheers barry
723371
Reply By: Member - Charlie M (SA) - Saturday, Apr 09, 2011 at 19:43
Big Woody
Go to auto pro or one of those stores and should have them in packets of 3 or 4 in various sizes. Made by Gee Jay works I think. Or any panel
shop should have them
Charlie
450797
Reply By: Member - Ed C (QLD) - Saturday, Apr 09, 2011 at 22:23
They're called "screw grommets"
Supercheap, Repco, et al have 'em in a variety of sizes
like these here
But yeah, I like the nutsert idea ;-)
Whichever you use, make sure ya use some sealant...
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
450809
Reply By: Big Woody - Saturday, Apr 09, 2011 at 23:03
Thanks everyone.
I too like the nutsert idea but hard to justify the purchase of the $89 tool just for a few fixings.
I might see if I can find someone who has the tool to borrow.
Thanks again
Brett
450813
Follow Up By: Lex M (Brisbane) - Saturday, Apr 09, 2011 at 23:20
I pull 6mm nutserts with a modified cheap hand pop rivet tool.
Pull it apart, take out the jaws and insert a long 6mm bolt from the back.
Don't try to pull it in one pull, Pull it a bit, screw the bolt in and pull it a bit more.
Works fine
723337
Follow Up By: Member -Pinko (NSW) - Sunday, Apr 10, 2011 at 08:02
Can nutserts be pulled up having a nut and washer and using two spanners. One holding the head of the setscrew and the other turning
the nut to crush the nutsert ?
723350
Follow Up By: Graham & Lynne - Sunday, Apr 10, 2011 at 08:32
Yes I have pulled them like that but use a allen head cap screw as is high tensile and thread goes all the way to the head and allen key is less hassle then the second spanner.
Thanks Graham
723356
Follow Up By: member - mazcan - Sunday, Apr 10, 2011 at 11:42
hi
lex m
and graham and lynne
thats very clever i will have a go at those ideas / methods
neva 'fort of dat daddy will be pleased
i broke the mandriel on my ome and waited ages for a costly replacement
thanks for the tips
barry
723373
Reply By: nickb - Monday, Apr 11, 2011 at 02:47
I just used self drilling screws with some silicone. 2 1/2 years on and it is still there, no leaks and no rust.
Doesn't answer your question but gives you an alternative if you can't get the nutserts.
450893
Reply By: Member - Phil G (SA) - Monday, Apr 11, 2011 at 20:49
In addition to whatever type of fastener you use, I add a strip of good quality double sided tape that holds it all very tight and seals it.
450993
Follow Up By: Member - Phil G (SA) - Monday, Apr 11, 2011 at 20:55
Found some photos that explain it better:
723526
