Garmin Quest GPS
Submitted: Monday, Apr 04, 2011 at 22:05
Trevor
I have Garmin Quest GPS which is about 4 years old and Garmin in their wisdom have withdrawn all support for it. The last set of maps they issued was 2009.
I am bit upset with this situation because the Quest is a terrific bit of kit. As
well as being a street navigator, it supports Tracks4aus, and Shonkey maps as
well as having a NEMA output which plugs directly into Oziexplorer.
My problem is the battery is on the way out and Garmin basically gave me the bums rush when I asked if they could change the battery.
My question - has anybody on this site changed a Quest battery themselves?
I don't want to pull it to bits and end up with the proverbial "spring up the nostril" and not be able to put it back together again.
Also does anybody know of an equivalent unit? One which will do street nav, work with Shonkey and Tracks4aus and with a NEMA output to work with Oziexplorer.
Trevor
Reply By: Bonz (Vic) - Monday, Apr 04, 2011 at 22:26
the Garmin GPSMap 60CS or 60CSx, or 76CS or 76CSx will do the trick for street nav as
well as Shonky t4a etc
Also does NMEA (not NEMA) output for Ozi, I have one of each model and they work a treat.
Google the batt replacement and you may find something there, the 60 and 76 units use normal AA batts so no issues there.
You can also use the Garmin GPSMap60 (thats black and white mapping) but it also autoroutes and does NMEA and shonky etc. The CS units are limited by their internal memory the CSx units use micro SD cards.
Good luck, I hate throwing out something that works cause the batts die
450370
Follow Up By: The Explorer - Tuesday, Apr 05, 2011 at 09:38
All those models are now discontinued so be careful. I think you can still pick them up here and there. Nothing wrong with them though so if you can get them at a good price - fine, just need to beaware of their status and accept associated risks
722886
Reply By: Member - res.q.guy (Vic.) - Monday, Apr 04, 2011 at 23:35
Hi Trevor
If you don't get an answer, on the battery here, you could ask on the GPS Australia
forum.
GPS Aust
Neil
450380
Reply By: Member - GeeTee (NT) - Tuesday, Apr 05, 2011 at 04:02
Try a google search for "Newpower99" in the states. They do a replacement battery kit , incl. screwdriver and plastic tool for opening it, for the Nuvi 760. I have one on order. I feel sure they have a replacement for your Quest.
Good luck GT
450383
Reply By: MrBitchi (QLD) - Tuesday, Apr 05, 2011 at 08:37
Here's a place in the States sell Garmin batteries
Garmin GPS Batteries
And here's a thread about replacing them..
Fixya
Enjoy..
450389
Reply By: Member - John D, Wandong (Vic) - Tuesday, Apr 05, 2011 at 09:23
