tv reception
Submitted: Monday, Apr 04, 2011 at 12:12
ThreadID: 85422 Views:2163 Replies:1 FollowUps:3
Hi all,
Has anyone had any experience with digimatch explorer tv antenna.I'm having problems and have'nt yet found which is at fault,the tv or the antenna.
kman
Reply By: TerraFirma - Monday, Apr 04, 2011 at 13:28
What sort of problems.? test the TV in a normal reception area, if it works as per normal then should be ok. I think you will need to be more specific with the nature of the problem, however this thread talkas about Digimatch antennas.
Thread: 39013
AnswerID: 450307
Follow Up By: kman1 - Monday, Apr 04, 2011 at 13:35
terraFirma,Problems are can't tune any signals either didital or analogue when van is in driveway at home.(old CRT tv works perfectly)Thanks kman
FollowupID: 722805
Follow Up By: TerraFirma - Monday, Apr 04, 2011 at 13:43
Old CRT TV or Digital TV LCD etc..?
Still not enough info unfortunately, here are some links for antenna support on Digimatch, perhaps call them and explain your issues, type of TV, antenna etc.
Antenna Support
Manual
According to the manual above there are some things you may or may not have done correctly, cabling, wiring, polarity of the antenna etc.? I suspect the TV is not the problem and you need to get the antenna assembled correctly.
FollowupID: 722807
Follow Up By: Member - Bill B1 (NSW) - Monday, Apr 04, 2011 at 15:47
I have a Happy Wanderer and I had similar problems with reception. My TV man said that there is too much resistance when using the wall plug on the van. If the signal is just a little but down in strength, the extra resistance will make a digital signal unuseable. I put the antenna cord through the side window.
I bought a signal amplifier to use on the inside and I have been getting good reception all round Oz.(WA is a bit iffy but that is just WA)
Bill
Bill B
FollowupID: 722818
