Snokel Head Foam Filters
Submitted: Saturday, Apr 02, 2011 at 13:55
ThreadID: 85381 Views:2513 Replies:9 FollowUps:3
G'Day,
I am about to embark on a trip along the CSR and was interested if any one had any comments on these filters.
Richard
Reply By: Member - Matt L (WA) - Saturday, Apr 02, 2011 at 14:24
Don't do it, all it will do is restriced your air flow and make black smoke out the back if it is a diesel.
AnswerID: 450079
Follow Up By: D200Dug- Saturday, Apr 02, 2011 at 14:37
Any filter will restrict airflow so the normal air filter is doing the same thing, especially one clogged with dust and dirt.
I would have thought a light primary filter to just filter out the worst of the crud and that was easy to clean at the end of the day would be an advantage ?
FollowupID: 722542
Follow Up By: D200Dug- Saturday, Apr 02, 2011 at 14:41
http://www.extremelimitsoffroad.com.au/category134_1.htm
I doubt people would sell stuff like these if they did cause a serious problem ?
FollowupID: 722544
Reply By: kiwicol - Saturday, Apr 02, 2011 at 15:04
Hi I have a 4.2 diesel patrol and i run foam oil filters in the pre cleaner and main filter.
If you run a paper filter as your main i would not put a oil foam filter before it.
The oil in the foam over time does get sucked out and puts a oily film over all the insides of the of the system.
When i get into dusty conditions i turn the snorkel head to face the rear, which helps.
For older vehicles i swear by the foam oil filters, they are messy to service, but carrying a spare sleeve already oiled is easy to fit in dusty conditions, and easy to clean in warm soapy water.
Cheers Col
AnswerID: 450084
Follow Up By: Kanga1 - Saturday, Apr 02, 2011 at 16:20
X2, if you have the type of snorkel head that is movable, makes a big difference. Cheers, Kanga.
FollowupID: 722554
Reply By: Kelvo - Saturday, Apr 02, 2011 at 18:25
I dont know what style of snorkel you currently have, but what about a cyclonic type?
http://www.google.com.au/images?q=NRC6920&oe=utf-8&rls=org.mozilla:en-GB:official&client=firefox-a&um=1&ie=UTF-8&source=og&sa=N&hl=en&tab=wi&biw=1024&bih=430
This type will not get blocked (Dust is spun out of the slits on the top) and no moving parts. The work better with higher engine speeds as more air is being pulled through it.
AnswerID: 450106
Reply By: Stu & "Bob" - Saturday, Apr 02, 2011 at 18:36
Put a donaldson type pre-cleaner head on your snorkle. It will capture most of the dust, and simple to empty out when needed.
AnswerID: 450107
Reply By: Member - Tony (ACT) - Saturday, Apr 02, 2011 at 20:06
The best way is to keep out of the dust as much as possible. Done the CSR with both Pre-cleaner ie round bowl and straight air ram style. The pre-cleaner works well, and would be my choice.
I only use paper filters and give them a blow out every day in dusty condittions.
AnswerID: 450114
Reply By: OREJAP - Saturday, Apr 02, 2011 at 21:39
Foam filters with the sticky solution restricts air flow just like turning the snorkel head backward. Paper filters can be "tapped" to get dust & rubbish out or the use of an air compressor is also an option. A motor requires the correct amount of air to operate proficiently restricing the amount of air to the motor causes poor efficiency. IMHO
AnswerID: 450120
Reply By: Rod - Saturday, Apr 02, 2011 at 22:49
I have used them for years and believe they are very good. Not on the CSR, but the Cape and GRR etc.
AnswerID: 450125
Reply By: carlsp - Sunday, Apr 03, 2011 at 07:08
I used to work for the foam manufactuer (Dunlop). Remember there is foam and there is foam. Air Filter foam is called "ME" and will have a numbr after it. So for a air filter it will be "ME10" There bigger the number the bigger the "holes" in the foam. It is almost always black but there is a blue one that looks almost the same. This is generally used for filtering water where there are fish involved. ME will kill fish.
I hope we are not talking about using mattress foam as a filter. You can get ME from Clarke Rubber or a good foam specialist.
AnswerID: 450139
Reply By: Member - Richard P (NSW) - Sunday, Apr 03, 2011 at 08:26
Thanks everyone for your most interesting and informative comments, I'll will do a bit more research on the matter.
Thanks again
Richard
AnswerID: 450148
