Caravan Roadworthiness
Hi Everyone.
Just a quick question regarding a secong hand caravan in Victoria, is there any requirement to submit a roadworthy certificate etc with the transfer of registration papers at the RTA.
I have spent a bit of time on this before and looking of the RTA website and while i do see that in some states a gas and electrical cert maybe required i am unsure for here. So far it doesn't seem so. I know if it has to be re-registered it has to be checked over at the RTA but that seems it.
If we don't, its pretty frightening considering there could be nearly 2 ton of van ripping down the highway someone just bought that may very well be teetering on the edge of disaster. A RWC for a rego transfer just seems logical, but is it required?
Any info would be greatly appreciated
Mauler
Reply By: Motherhen - Friday, Apr 01, 2011 at 14:52
I don't know what the roadworthy certificates cover - perhaps that the lights are working, and maybe gas and electrical certificates up to date? However none of these would cover the problems which may have "nearly 2 ton of van ripping down the highway someone just bought that may very well be teetering on the edge of disaster". For faults which may occur to cause this, i think it is still buyer beware, and even then they may well not be obvious.
Those from states with these requirements may be able to correct me or clarify.
AnswerID: 449975
Follow Up By: Member - Bruce C (NSW) - Friday, Apr 01, 2011 at 15:04
Hi Motherhen,
Here in NSW they are supposed to do a complete vehicle check just as they do for a car or truck.
This means suspension checks, tyre checks, chassis checks for fractures just as they would in a car, gas bottles securely fixed in place and able to withstand a rollover, lights and general state of the vehicle such that there is nothing to jag an innocent pedestrian walking by and rear bumper in case it could be just about to fall off and take out the vehicle behind.
These are the many things my inspection station checks and I think it is a cheap vehicle inspection and safety check for my personal well being as well. Good value in my opinion at around $30.00.
Cheers, Bruce.
FollowupID: 722413
Follow Up By: Member - Bruce C (NSW) - Friday, Apr 01, 2011 at 15:22
Interestingly we only have to have a gas inspection on cylinders every 10 years and the vehicle has to be plated according to the appliances fitted therein.
I have never been asked for an electrical certificate and as we had to have the brothers imported motor home set up with 240 volts recently we got a certified electrician to do the work and he said that there was no certification certificate required in NSW.
We think that it will only be a matter of time.
From what I have read in many places some of the wiring coming out of some of the van manufacturers leaves a lot to be desired. I have heard many stories re a certain nationally known brand of van where the electrical installations have had to be stripped out and replaced. No names, no pack drill.
Cheers, Bruce.
FollowupID: 722420
Follow Up By: Motherhen - Friday, Apr 01, 2011 at 15:35
No roadworthy inspection would see what is under the skin, and that is generally where all the problems lurk.
Mh
FollowupID: 722431
Follow Up By: Member - Jayco_Mauler (Vic) - Friday, Apr 01, 2011 at 16:03
Thanks very much for the replies / follow ups and i will definately look further into it. I think the idea of getting it inspected prior to purchasing is a great idea so i will have a look around to see who local actually does it and knows their stuff.
I guess i was not expecting xray vision, just thought that they would have to atleast be inspected to ensure tyres, suspension, gas and electrical certificates... the basics i guess.
I have tracked down a branch of Vic roads where a guy is apparently right up with it so i will chase him up and forward any info along just incase anyone from Victoria is interested.
Brendon
FollowupID: 722443
Follow Up By: Member - Bruce C (NSW) - Friday, Apr 01, 2011 at 18:37
You know Motherhen, it is pretty crazy really, we are 22 million people in Australia.
This is the population of just one of many major international cities yet we have that many different sets of regulations, so many little fiefdoms so to speak, and nobody is going to let common sense ruin there little party.
Should be one set of rules right around the country so no one gets confused.
The other one that gets me is that they tell us we the biggest polluters per head of population. While that may be true, to run a country this size we virtually cannot help it. We are being conned so that they can hit us in the hip pocket so to speak. But tha'ts another story.
Cheers, Bruce.
FollowupID: 722466
Follow Up By: Motherhen - Friday, Apr 01, 2011 at 18:48
Hi Bruce
State Government Departments seem to treat their counterparts in other states as hostile enemies. We are one country, so rules and regulations should be the same across the board. They have moved to uniform drivers licence classifications - but still they are state not federal licences. There has been some streamlining of road rules but not enough. With other transport matters it is pot luck what you get in your state; they are all different.
From me in the land of WA to you in that far distant land of NSW.
FollowupID: 722467
Reply By: Member - Bruce C (NSW) - Friday, Apr 01, 2011 at 14:54
Hi Mauler,
If the vehicle is already registered and considering here in NSW you have to have an inspection every 12 months or no rego, can't see that there would be a problem. In Vic the situation may be different.
However some states require an inspection certificate before sale of vehicle (QLD)
and I read where one poster to these pages was fined (again QLD) for not having one done prior to advertising the vehicle for sale. I can see why in QLD as they don't have to have an inspection every year so the state of some QLD vehicles gives us a shock here in NSW. May have changed in recent times, cannot say.
Cheers, Bruce.
AnswerID: 449976
Follow Up By: Member - Jayco_Mauler (Vic) - Friday, Apr 01, 2011 at 16:10
Hi Bruce,
I have bought many cars from NSW for the very reason they have to go over the pits every year to keep their rego so i am glad to hear that caravans need to meet the same minimum.
Atleast with Victoria cars, as long as the rego is paid, a car with one owner may never be inspected for roadworthiness in theory, its only if it is sold with registration that it needs to be certified.
I will have the facts soon enough but its still good to learn of other people experience so i go in with my eyes open.
Mauler
FollowupID: 722445
Follow Up By: Member - Bruce C (NSW) - Friday, Apr 01, 2011 at 16:48
Thanks for that Jayco,
I had been looking at several cruisers in Vic in the past with a view to buying one but now that you have given us a heads up on this subject I will be very wary in the future.
Cheers, bruce.
FollowupID: 722454
Reply By: Member Ray M (QLD) - Friday, Apr 01, 2011 at 15:01
Hi Jayco_ Mauler
Interesting name, is there a story behind that? coz by the sounds of that you are never borrowing my Jayco... LOL
Cheers Ray
AnswerID: 449977
Follow Up By: Member Ray M (QLD) - Friday, Apr 01, 2011 at 15:04
By the way welcome to EO, I see you joined up 2 days ago
Cheers Ray
FollowupID: 722414
Follow Up By: Member - Jayco_Mauler (Vic) - Friday, Apr 01, 2011 at 16:25
Hi Ray,
Thanks for the welcome! I have been lurking on here for a few months trawling for info but recently decided to join due to the great support the site and its members gave.
My father in law had an old Viscount that they had used for years and it was looking a little tired so being a joiner by trade i stripped all the cupboard fronts and bench tops , put in new overlay flooring and generally dressed the old girl up with new laminates and fittings. They were absolutely rapt. My family and i went on a 3 week holiday 6 months later and when we got home they had sold it and bought a brand new one claiming that my work had gotten them a wonderful price.... just can't pick family can ya.
So i recently purchased an old viscount myself and was going to do the same thing only it was in an accident in transit. I had already called myself Viscount_Mauler based on the fact i was going to fix one up again but not to be. I am now looking to a Jayco campertrailer based on some very good advise received here so thought i better switch the name to make it relevant.
I look forward to spending alot more time on here, i have been reading through some of the blogs..... we just got back from tasmania but after reading some of the blogs from people who went we drove past everything!! It won't happen next time. There is so much to see it Australia and its so easy to drive right past something brilliant and not know!
Brendon
FollowupID: 722448
Reply By: Member - DW Lennox Head(NSW) - Friday, Apr 01, 2011 at 15:09
Hi Mauler
Why don't you contact the relevant authority to get the correct information?
I do not doubt the other replies but the one that counts is that State body. You cannot blame anyone then. Not many of us know the laws thoroughly.
DW
AnswerID: 449978
Follow Up By: Member - Bruce C (NSW) - Friday, Apr 01, 2011 at 15:27
I second that Jay.
You must hate your mum for calling you Jayco!!! And I would change my surname by deed poll if I were you mate. LOL LOL
Bruce
FollowupID: 722424
Follow Up By: Member - Bruce C (NSW) - Friday, Apr 01, 2011 at 15:31
Sorry DW,
meant to put it in Rays post above.
Bruce.
FollowupID: 722426
Follow Up By: Member - Jayco_Mauler (Vic) - Friday, Apr 01, 2011 at 16:37
Hi DW,
Thanks for the info and advise and rest assured i am checking with the relevant bodies, but i have found that it pays to do your homework before turning up to discuss rego etc with Vic Roads. The times i have waited 3 hours to be told i needed something else and then rejoin the cue still burns.
I am definately not looking for people to blame when i ask advise, its just quite often many people actually know the answer because they have been through the process, or can shed a little light on it atleast.
Thanks again
Mauler
FollowupID: 722450
Follow Up By: Member - Jayco_Mauler (Vic) - Friday, Apr 01, 2011 at 16:53
Hi Bruce,
After many years in the trade and on construction sites, i pretty much answer to anything now. I was actually wondering whether i may find myself coming under fire through copyright (Jayco) when i become a famous and intrepid Oz Explorer........ Oh well, one problem at a time ;O) I maybe forced to change it to Forum_Mauler instead.
Mauler
FollowupID: 722457
Follow Up By: Member - Bruce C (NSW) - Friday, Apr 01, 2011 at 18:27
Hi Brendon, (Jayco)
An old plumber myself mate, know exactly what you mean about the building game. They take no prisoners there.
No mate, leave the forum in one piece we all need it, no mauling here. LOL
Cheers and welcome again,
Bruce.
FollowupID: 722465
Reply By: Member - NellnPete - Friday, Apr 01, 2011 at 15:47
Hi Mauler,
Cetificate of Roadworthiness is not required in Victoria, just proof of ownership,
ie. receipt of purchase along with a signed notice of disposal/acquisition.
Hope this helps.
Regards,
Pete.
AnswerID: 449982
Follow Up By: Member - Jayco_Mauler (Vic) - Friday, Apr 01, 2011 at 16:43
Hi Pete,
Thanks alot for the info because that is pretty much all i could find myself. Basicaly a receipt and a signed declaration for the transfer of ownership. Atleast i know where that leaves me and its just a matter of being very thorough when checking them out.
Brendon
FollowupID: 722451
Reply By: Member - John B2 (VIC) - Friday, Apr 01, 2011 at 16:20
In Victoria we have Vicroads no RTA are you looking at the right website?? :-)
AnswerID: 449988
Follow Up By: Member - Jayco_Mauler (Vic) - Friday, Apr 01, 2011 at 16:47
Hi John,
Yep slip of the tongue that one, old habts die hard. It is the VicRoads site that i have been snuffling through not the Road Traffic Authority site. Thanks for making sure though ;O)
Brendon
FollowupID: 722453
Follow Up By: Member - Bruce C (NSW) - Friday, Apr 01, 2011 at 16:56
That's the shot Brendon, a first name.
Nobody bites here but if they do we put a muzzle on them, don't we folks. LOL
Cheers, Bruce.
FollowupID: 722458
Follow Up By: Member - John B2 (VIC) - Friday, Apr 01, 2011 at 17:12
Hi Bruce,
I am with you a first name is more personal than a nickname when signing off :-)
FollowupID: 722461
Reply By: Shaker - Friday, Apr 01, 2011 at 17:53
There is no requirement for a RWC in Victoria for a Caravan or trailer, unless it has commercial registration.
AnswerID: 449993
