Wednesday, Mar 30, 2011 at 17:35
You can fit brakes to a trailer that by weight does not require it, but must fit them as prescribed at the specified weights. Under 750 kgs GTM (rather than ATM) on the plate, fitting of brakes is optional (but wise). Fitting of brakes will not alter the weights on your compliance plate.
Vehicle Standards Bulletin VSB1 - Regulations for trailer braking
15. BRAKING
15.1 Trailers that do not exceed 0.75 tonne GTM with a single axle
No brakes are required.
(For further information, refer to ADR 38/02 clause 5)
Note
Two axles with centres spaced less than 1 metre apart are regarded as a single axle.
15.2 All other trailers that do not exceed 4.5 tonnes ATM
These trailers must be fitted with an efficient brake system that complies with ADR 38/-. Except for over-run brakes, all brakes must be operable from the driver's
seat of the towing vehicle.
For trailers up 2 tonnes GTM, an efficient braking system is considered to have brakes operating on the wheels of at least one axle. Over-run brakes may only be used on trailers that do not exceed 2 tonnes GTM.
Every trailer over 2 tonnes GTM must have brakes operating on all wheels. The brake system must cause immediate application of the trailer brakes in the event of the trailer becoming detached from the towing vehicle. Under these circumstances, the brakes must remain applied for at least 15 minutes.
All flexible hydraulic brake hoses, air or vacuum brake tubing and air and vacuum flexible hoses must conform to SAA, SAE, BS, JIS, DIN, ISO or ECE Standards and be fitted to the vehicle in a way that will prevent chafing, kinking or other mechanical damage under normal motion of the parts to which they are attached.
Definitions:
GTM / Gross Trailer Mass
is the weight supported by the axle/s or wheels of a loaded trailer when attached to the tow vehicle
ATM / Aggregate Trailer Mass
is the total loaded weight of a trailer including the tow ball download; weight when not attached to the tow vehicle
Clear as a turbid river?
449729
Follow Up By: cycadcenter - Thursday, Mar 31, 2011 at 06:43
According to ADR the weight capacity of the Axle must be stamped on the Axle by the manufacturer.
722208
