Size of Forum Page
Submitted: Monday, Mar 28, 2011 at 14:41
Kirks
Kirks here
Why is my
forum page not using the full size of my pc screen, don't know whether should be asking this question here or not.
Thank you.
Reply By: Member - Rod N (QLD) - Monday, Mar 28, 2011 at 15:17
I noticed a similar thing and the full thread headings could not be seen. I had to use CTRL and scroll wheel to enlarge the page. When I enlarge it enough to see the whole description line under the thread title the page size is larger than the screen which requires sideways scrolling. I am using Firefox 4.
It would be good if all the different browsers would stick to a standard HTML. I have found Firefox, IE and Chrome can render the same site in different ways.
449469
Follow Up By: Wokwon - Monday, Mar 28, 2011 at 15:24
The good thing about standards is that there are so many to choose from.
721848
Reply By: Member - MUZBRY(Vic) - Monday, Mar 28, 2011 at 15:52
Gday
Press command minus a couple of times ...
449471
Reply By: Baz&Pud (Tassie) - Monday, Mar 28, 2011 at 16:58
Go to the bottom right of the screen and you will see a % screen click on that to increase the size of the screen.
Bas
449475
Follow Up By: Member - Boo Boo (NSW) - Monday, Mar 28, 2011 at 19:13
Thanks B&P
I happened to have had the same problem about 1 minute ago.
721864
Reply By: ExplorOz - David & Michelle - Monday, Mar 28, 2011 at 20:26
Quickest way to reset zoom is - Press and hold CTRL then press the number 0 - it s almost a standard on the browsers so give this a try and you will be reset - you can make adjustments with CTRL + and CTRL -
Enjoy.
David
449505
Follow Up By: Kirks - Tuesday, Mar 29, 2011 at 14:06
Thanks everyone for your help everything ok for now untill i press the wrong key.
Thank you
Kirks
721926
