Prado Fuel Fault
Submitted: Saturday, Mar 26, 2011 at 18:19
dan t2
Hi Readers,
Iam requesting some assistance's with a problem that I have. My vehicle of choice is a 08 diesel Prado, auto with 180k. Recently it has been having fuel fault issues. Sometimes the vehicle dies for 4 to 8 seconds and then comes good, other times it goes to limp mode and has to be turned off and restarted. This can be done on the roll with the vehicle in neutral. Once vehicle is restarted it is good go. On a recent trip
Townsville to
Brisbane it faulted 12 times in the first 450kms. After having the fault code cleared twice (RACQ & Toyota dealer). It completed the following 3600kms with no issues,2 days back
home and the fault is reappearing (it does not seem to like city driving). Local dealer said not much can be done at the moment as fault code has been cleared and will have to wait for code to reappear. Was serviced prior to trip and no contaminates found in fuel filter. Symptons same as (Hightower Nov 7 2009) but code was for fuel falut not air intake temp sensor. Any
feedback will be appreciated.
Cheers.
Reply By: PeteS - Saturday, Mar 26, 2011 at 19:05
G'day dan t2
I suggest you also try Pradopoint
Pradopoint link.
I also use a Scanguage
Scanguage link which also shows fault codes and you can reset them. The Scanguage also displays a heap of readings and it's one of the easiets devices to fit, it simply plugs in.
Toyota (most car suppliers for that matter) seem have no idea on the exact problem unless their computers tell them so. An intermittent fault is hard to find.
Best of luck mate, I hope you get to the end of it soon.
PeteS
449312
