PL259 & S0239 connectors help please
I wish to connect a PL259 from a UHF aerial onto a wall plug so as to access a UHF inside a 'van. ......using RG58 cable
I have one of these that I hope to put into a standard knock out hole on a clipsal switch wall panel (bit of modification needed).........but the soldered end I am unsure about........what happens with the sheath around the cable?.............
When fitting the screw on PL259 fitting onto cable I realise you solder the inside pin carefully and when fitting the sheath gets a good grip on the screwed collar......that is quite straight foward and have done many times in the past
But the other end of this panel jack has me a little unsure........ once I solder the inside pin on the cable what do connect the sheath to?....or dont I?
Image Could Not Be FoundImage Could Not Be Found
Is there a better way of doing this?....or a better fitting to use?
I have looked at the easy eye and another brand but neither will allow the PL259 on the aerial cable through their small opening
VKS 1341
Reply By: Bonz (Vic) - Saturday, Mar 26, 2011 at 11:16
Gather the shielding, twist it tegther into a crimp and terminate it on one of the screws holding the plate to the bracket
AnswerID: 449285
Reply By: Gone Bush (WA) - Saturday, Mar 26, 2011 at 11:16
Graeme,
those fittings are fine but a bit bulky.
I would use a BNC plug and socket.
I can post you a plug for RG6 but you would have to get this socket from Jaycar.
BNC Crimp Socket
Then you could still use the Eze-eye if you wanted to.
AnswerID: 449286
Follow Up By: Gone Bush (WA) - Saturday, Mar 26, 2011 at 11:19
If you want to, email me photos of the bits that you already have and exactly what you want to do, and I'll put my thinking cap on.
FollowupID: 721636
Follow Up By: Member - bungarra (WA) - Saturday, Mar 26, 2011 at 12:04
Hi Stephen
I already have one fitting as in the picture and also the magnetic antenae mount / cable has the PL259 on RG58 cable
The UHF will be in the van permanently but I am using a magnetic mount ground independent antenae so I can put up and down as it suits me and just connect the coax to the UHf each time I set the antenae up.
Therefore the ezy eye is definately the way I want to go as it will be cleaner, neater etc. My post showed the only way I could see at the moment
From the picture it appears the BNC crimp socket is simply an inline joiner type connection that consists of plug / socket?
if so does it take the RG58 cable and do you reckon it would pass through the ezy eye?
Graeme
VKS 1341
FollowupID: 721643
Follow Up By: Gone Bush (WA) - Saturday, Mar 26, 2011 at 12:11
Graeme,
You can buy a PL259 plug to BNC socket adapter.
This can be screwed onto the socket on the back of the UHF.
Then put a BNC plug onto the RG58 cable from the antenna. This will pass through the Eze-eye.
Eze, aye.
FollowupID: 721644
Follow Up By: Gone Bush (WA) - Saturday, Mar 26, 2011 at 12:14
Jaycar PL259 to BNC adapter
FollowupID: 721645
Reply By: Member - res.q.guy (Vic.) - Saturday, Mar 26, 2011 at 11:21
hi
The centre of the coax is soldered to the pin, and the shield is connected to earth, the body of the fitting.
You may be able to use an Ezy Eye (or similar)
Ezy Eye is 3 products down on the link below.Ezy Eyedepeding on the plug / hole size.
Neil
AnswerID: 449287
Reply By: Gone Bush (WA) - Saturday, Mar 26, 2011 at 11:27
Another question Graeme,
is the UHF going to stay in the van full time?
Or is it used elsewhere then taken to the van when you go on a trip?
I had the UHF fitted in my van and connected to an antenna on the Wingaurd TV antenna.
AnswerID: 449288
Reply By: SteveL - Saturday, Mar 26, 2011 at 14:44
At UHF frequencies, using several PL259 type fittings and joiners will cause considerable signal loss and SWR problems. Far better to avoid using them whenever possible.
AnswerID: 449297
Follow Up By: Gone Bush (WA) - Saturday, Mar 26, 2011 at 15:50
Convenience far outweighs any minor (not considerable) signal loss and any impact on SWR is negligible.
FollowupID: 721667
Follow Up By: vk1dx - Saturday, Mar 26, 2011 at 18:50
Sorry Bushy but I agree with Steve.
The PL259 is recommended for HF and maybe VHF frequencies. It is used for UHF CB as a cheap and readily available alternative. Most other UHF systems utilises "N" type connectors. You can lose more than half your signal with just one single PL259.
That's not what I would call minor when the range is a max of 15Kms (approx) on moist or wet ground.
I also noticed in someone's photo, that a UHF antenna is mounted on a TV support mast. The antenna is "down" the side of the mast right next to the metal mast that is grounded. Or if its not, is should be. That would KILL more than half the signal. Mount it up above and away from the TV antenna, preferably on a separate pole.
FollowupID: 721689
Follow Up By: Gone Bush (WA) - Saturday, Mar 26, 2011 at 18:59
That's the closest photo I could find.
It's actually a Next G antenna.
FollowupID: 721690
Follow Up By: vk1dx - Saturday, Mar 26, 2011 at 19:21
Fair enough. May I suggest that you do the same for it. Move it at least above the metal mast. Where it is its like putting a metal pipe over it and shading it from the signals. Even if its open on one side.
FollowupID: 721693
Follow Up By: Gone Bush (WA) - Saturday, Mar 26, 2011 at 21:38
vk1dx, essentially, I agree with you but the practicalities are that the off the shelf stainless mounting bracket would foul with the bulky part of the Wingaurd when it folds down.
In its present position it is clear of that bulky piece.
Short of custom making the antenna bracket (via an angle grinder) the line of least resistance is as shown.
On my own van I have both a Next G and UHF CB antenna on the Wingaurd.
I haven't used the Next G because my Iphone doesn't have an external antenna socket and those passive things are useless, but the UHF antenna works fine within the constraints of how we use it, ie, close range van-to-van or van-to-handheld.
FollowupID: 721704
Follow Up By: vk1dx - Saturday, Mar 26, 2011 at 22:16
All cool. If one went around dictating what people must do to their comms and such then one would have a very loney life. I am far from dictating. That's why I use words to suggest how to improve things. And exactly why I said "preferably on a separate pole".
Practically the radio appears to be satisfying your needs. But remember the close metal pole will be causing a missmatch internally to the antenna, coax and the innards of the radio. In the vernacular of the CBer its quite possible that it is not SWARED in correctly. And if not so the incorrectly matched antenna system will be "fighting" with the PA final circuitry and more than likely lessening the serviceable lifetime of the components in the radio and may make it fail at any time. Or you may be lucky and it will outlast both you and I.
Personally I would find another mount. Maybe an antenna base, not a ground independant base, in the roof of the van and remove the antenna when on the move. That's where I put one before we ditched the van. I also had a full amateur radio station installed in the van. HF, VHF and UHF radios as well as PA's (capable of 1.5 kilowatts ), antenna patch and antenna rotation controllers. I do not use ground independant antenna bases.
I do not know the site parameters and cannot comment any further.
Anyway, lets face it, UHF is not the best for any mobile radio setup. Too many shortcomings. But it helps. And its free.
FollowupID: 721709
