oziexplorer vew vehicle speed
Submitted: Thursday, Mar 24, 2011 at 18:39
ThreadID: 85205 Views:2501 Replies:2 FollowUps:9
hello all,
what is best way to view the speed of vehicle in ozi explorer
i use View / Track / Track profile
is there a better way for example to export my tracks into google earth
to have a better view of the speed at a certain point or time ?
thanks for any info
Rob
Reply By: Member - Kiwi_In_Aussie(Wagga) - Thursday, Mar 24, 2011 at 22:19
If you go to this website
OziSpeed2
and take a look at Ozispeed2 - it might be what you are looking for - dont forget to d/l the Oziapi.dll file that it refers to - it wont work without it
K.A
AnswerID: 449167
Follow Up By: The Explorer - Friday, Mar 25, 2011 at 00:01
I think Rob is talking about track replay ...on the PC at home, but his post is a bit ambiguous. Thanks for the link none the less - handy add on for those who use PC version of OziExplorer in their car. OziCe version has the option for similar speed display.
FollowupID: 721501
Follow Up By: MrBitchi (QLD) - Friday, Mar 25, 2011 at 11:04
You don't NEED OziSpeed2 but it does give a large (up to full screen) display. If you press "Ctrl M" (moving map control) then your speed, heading, altitude etc is displayed o the screen.
FollowupID: 721525
Reply By: robairlb1@yahoo.com - Friday, Mar 25, 2011 at 00:18
I guess the post was not clear enough thanks for the reply,
but what i need is to view the speed at a certain point of the track
if i save a track from ozi as a .plt file and open in google earth, i can see only the route and timings of the trip but i still need to add the speed at each minute if possible, i searched a lot for some tools but could not find any
i appreciate any help
kind regards
Rob
AnswerID: 449179
Follow Up By: Member - MYPRADO - Friday, Mar 25, 2011 at 00:47
Sorry to but in my oziexplorer shows arrow what direction but does not leave a trail where i was, is there a button i should press.
Much appreciation thanks.
FollowupID: 721502
Follow Up By: MrBitchi (QLD) - Friday, Mar 25, 2011 at 09:21
Press "Ctrl T" and it will show the track on screen. You can save the track to a file at any time.
FollowupID: 721516
Follow Up By: The Explorer - Friday, Mar 25, 2011 at 11:42
Rob Hi again
Is there a reason you have to use Google Earth and not OziExplorer with Google Earth loaded?
That way you can load the track file and either look at the track list to see speed (etc) at any one point or run the track replay to get the same imformation as the track replays- - see below (some of my speeds are obviously a bit out:)
Image Could Not Be Found
FollowupID: 721528
Follow Up By: robairlb1@yahoo.com - Friday, Mar 25, 2011 at 17:29
thanks Greg
this is what i want , but i could not load the menus as you have
how to see Track List menu and Track replay control
thanks
FollowupID: 721557
Follow Up By: The Explorer - Friday, Mar 25, 2011 at 17:47
They can be opened using the same menu you use to open the Track Profile i.e. VIEW->TRACKS->TRACK REPLAY
and
VIEW->TRACKS->TRACK CONTROL - - afte you have the track control open click on the 4th icon along the bottom row of icons to open the Track List.
Obviously you need a track loaded first.
To get Google Earth loaded in OziExplorer (if you havent already) make sure you have latest version and also download needed internet map files from Ozi websitehere.
FollowupID: 721563
Follow Up By: robairlb1@yahoo.com - Friday, Mar 25, 2011 at 18:01
works great
thanks a lot
FollowupID: 721565
Follow Up By: Member - MYPRADO - Saturday, Mar 26, 2011 at 00:18
FollowupID: 721608
