12v electric blankets??
Submitted: Monday, Mar 14, 2011 at 20:40
Polky
Gday,
just wondering if anyone has heard of 12v electric blankets, and if so where can we get them and how much do they cost? Does anyone have any other heating alternatives for a family with small kids in a camper trailer???
Reply By: Nifty1- Monday, Mar 14, 2011 at 20:59
I think the shot is to use a standard 240v blanket, but use an inverter. I think they are quite low wattage, and from memory a 150w inverter will drive one.
448243
Follow Up By: Polaris - Tuesday, Mar 15, 2011 at 10:48
We use a Sunbeam QS electric blanket - 2 individual controls - works fine from our 600W inverter.
Spec on the blanket quotes power as 20W to 80W on each side, depending on the heat setting.
Put it on max for 10 min prior to hopping in - then reduce to min for the rest of the night.
Have never had low battery issues.
720609
Follow Up By: Polaris - Tuesday, Mar 15, 2011 at 10:52
Follow up to previous post.
We initially tried to run the EB from a mod sine wave inverter - without much joy at all. The problem was that our EB has electronic controls and the mod sine wave unit was too dirty. Replaced the inverter with a full sine wave and then it all worked fine.
If the EB that you use has a conventional control, then you won't have this problem and it will run from a mod sine wave inverter.
720610
Reply By: Member - Rod N (QLD) - Monday, Mar 14, 2011 at 21:00
Reply By: farouk - Monday, Mar 14, 2011 at 21:03
NO but I have a mate who usied a inverter 12v to 240v to warm the bed for an hour whilst
camping out and it only used about 5 amps of his battery storage.
Colin
448247
Reply By: Mick O - Monday, Mar 14, 2011 at 21:15
I’ve travelled a fair bit of the wide brown land with a recently retired couple who will remain nameless but drive a deep blue 80 series and ride a black Arctic Cat quad. These two have always impressed me with their willingness to abandon a warm campfire on even the coldest of desert nights for the roof top or Ultimate Camper based doona. This is because they’ve been warming up the workbench with their electric blanket. It’s a totally standard 240 volt blanket run through an inverter, in their case a 1000W pure sine wave Cotek from Redarc. Their dual battery system copes with the amp draw required comfortably so I’d probably suggest that there’s no need to go down the complex path of a DC blanket. If you’ve got decent dual battery system and an inverter, warming the cot may be a simple proposition (I find sending your better half to bed a bit earlier always helps as
well ;-)
Cheers Mick
448249
Follow Up By: Polky - Monday, Mar 14, 2011 at 21:43
Thanks Mick,
Might have to look into a decent inverter then. I have a decent dual battery system that should cope okay. Got to keep the missus and kids happy!! A happy wife means a happy life if you know what I mean!!!
720572
Follow Up By: Mick O - Monday, Mar 14, 2011 at 22:13
Mate that was always Mick O's rule no. 5! Happy wife...happy life. I'll chase Member Jaydub up and get him to provide you with some first hand user experience..damn I've outed him as the electric blanket user lol.
Cheers Mick
720576
Reply By: Peter_n_Margaret - Monday, Mar 14, 2011 at 21:37
12V electric blankets are available, but they are much more expensive than a 240V one.
We run a 240V electric blanket via an inverter in the OKA.
each side (double) uses 5A (60W) on the highest setting. Usually it is sufficient to warm up the bed for 30 minutes on high and then turn it off. If you intend running for longer than that (and running them for the kids as
well) you would be
well advised to calculate the power consumption very carefully to ensure that your batteries and charge system can cope OK.
OKA196 Motorhome.
448251
Follow Up By: Polky - Monday, Mar 14, 2011 at 21:45
Thanks Peter, I will have to look for a decent inverter because we would be running them for the kids as
720574
Reply By: Member - MUZBRY(Vic) - Monday, Mar 14, 2011 at 21:57
Gday
I have a 12 volt blanket , little brother gave it to me and it has never been used.
448255
Reply By: Millsy - The Uteshed(WA) - Monday, Mar 14, 2011 at 23:30
My boy suffers from asthma and have always used a 240V electric blanket in the RTT & run it of an aux 100A/H battery with a 600W inverter on it. Turn the blanket side ways and turn the top half on to #1 and run it all night if is cold or damp. I think our blanket draws 150watt with both sides on setting #3.
It fitted to the CT now ready for a trip to the Red Center at
Easter Time just in case.
448260
Follow Up By: Member - Jdub - Tuesday, Mar 15, 2011 at 10:06
What can I say, my cover as the best sheet warmer is blown!
Our 240 volt blanket is rated at 70 watts per side so even the previous Powertech 300w inverter was sufficient for a one hour blast before bed.
Hearsay only, states the 12v jobbies are a bit weak.
Cheers John
720605
Reply By: Robin Miller - Tuesday, Mar 15, 2011 at 10:44
They are available and draw approx 55 watts , you can even get them for dogs.
Mostly we are away from 240vac and the 4 amps or so current draw is to much anyway and I considered the product fragile with potential to short out.
Anyway , a $2 hot
water bottle kills them for performance overnight.
Often though bed only needs shorter duration warmth , and we find the use of a wheat bag suits the purpose better , easy to kick out of bed when to hot and no risk of kids breaking.
Even have a 12v stove , whose job , after cooking Xmas pudding this weekend, was to heat the bag.
This means you don't drag down battery overnight as we usually
camp in isolated spots.
448292
Follow Up By: Shaker - Tuesday, Mar 15, 2011 at 11:36
My wife uses a hot
water bottle as
well, the
water is warm enough in the morning for a quick wash too, if we are "on the road".
720616
Reply By: Member - Alex B - Tuesday, Mar 15, 2011 at 14:23
Hi Polky,
Agree with the above. We use a 240V electric blanket through a 600w inverter.
We run it for an hour or so before bed time to take the chill off.
Works
Alex
448315
Reply By: Motherhen - Thursday, Mar 17, 2011 at 01:48
Hi Polky
Unless your children have a medical need such as asthma and need additional heating, rug them up with track suits over their 'jamas and woollen bed socks, then tuck them up in sleeping bags. If the beds are out in the air like in slide out bed wind up trailers, put insulation under the mattress as much as covers over them (even old newspapers).
We have not travelled to the snow country, but have camped in stiff frosts and the only time we were cold was just once when we had a camper with slide out beds, when the air got rather cold a bit before dawn. When we got to a nearby town they'd had - 4º and it would have been colder where we camped. I have camped in Norway and woke to find it snowing, and was cosy in a sleeping bag with a blanket over the top.
As aforesaid, if you do use electric blankets, be sure your batteries have the capacity. If needing one just to warm up their beds, try hot
water bottles.
448451
