4wd tyres for Nissan X-Trail
Submitted: Monday, Mar 14, 2011 at 14:44
tastpa
Hi everyone.
I have a 2010 Nissan X-Trail, which I have just bought some 16" wheels (it came standard with 18") so as I can fit some better 4wd tyres on. I am planning a trip from Melb to QLD, NT and WA which will involve some on-road as
well as off-road exploration. I was wondering about opinions about the type of tyres to put on for the trip. I have been told that BF Goodrich are good, but also been told that they are impossible to balance. Have also had info that Coopers 70/30 tyres are good for such a trip.
I am open to listening to all thoughts on the matter!!! Thanks for your time
Teha
Reply By: Member - cuffs (SA) - Monday, Mar 14, 2011 at 15:43
Reply By: Batt's - Monday, Mar 14, 2011 at 18:57
Whoever said you can't balance BFG's dosn't know what their talking about or maybe had a bad batch of tyres which can happen with any brand I've been around Aus in all conditions on BFG AT's they'll serve you
well their great in all conditions and should be good for 80'000 to 100'000 km
448220
Follow Up By: gbc - Tuesday, Mar 15, 2011 at 06:36
I've had 4 sets of BFG. They can be balanced and will serve
well. My cooper ST's delaminated, but I've had AT's, STT (old pattern), and LT's that were o.k.
720592
Follow Up By: gbc - Tuesday, Mar 15, 2011 at 06:37
Personally on a car like that I'd look at a 694 dueler. Or a Pirelli scorpion AT.
720593
Reply By: mikehzz - Monday, Mar 14, 2011 at 23:43
Yoko Geolander At/S are excellent. Coopers seem to be the most controversial tyre out there. Opinions are very polarized and I'm not getting further into that. Mike
448263
Reply By: Member - Phil G (SA) - Tuesday, Mar 15, 2011 at 09:10
You will find it hard to get offroad tyres in the original 215/65R16 size. But if you want to use this size the Bridgestone D683 or Pirelli P6 are good highway tyres. Also the Bridgestone D693 may still be available in this size.
If you upsize to 215/70R16, more options become available such as BFG ATKO and Bridgestone D694.
My preference would be to upsize and use the D694's
448284
Follow Up By: Member - Phil G (SA) - Tuesday, Mar 15, 2011 at 09:11
Also, I've assumed you're not towing. If you are towing I wouldn't upsize.
720601
Reply By: Kimba10 - Tuesday, Mar 15, 2011 at 09:37
Have had 3 sets of BF's A/T's on 3 different vehicles and never ever had an issue with balancing, no wheel vibrations, pulling nothing, nice and smooth. You will definately get more tyre noise with any A/T tyre possibly more so with the BF's as they have a pretty aggresive side on them compared to Geolanders etc but Im only talking minimal. Great tyre as an allrounder, useless in very muddy clay conditions as the tread fills up but there not a mud tyre. Never had a punture in any of them and all up those tyres/vehicles covered roughly 350 thou. Regards Steve
448286
Reply By: broometime - Tuesday, Mar 15, 2011 at 11:25
i would use bridgestone dueler 694 lt or bfg. i had coopers in the kimberly, they seperated in the heat.
448299
Reply By: Member - Des - Tuesday, Mar 15, 2011 at 13:41
It depends a lot on what kind of "off-road exploration" you have in mind for your trip, as
well as the likely weight of the vehicle and whether you are going to tow. There are compromises whichever way you go. For example going a size larger will increase ground clearance, but affect gearing. LT construction tyres will be more
puncture resistant, and carry a heavier load, but provide a harsher ride.
I would start by working out whether you want tyres in the original size. (There are advantages in sticking with the original size. The gearing won't be changed, downhill engine braking won't be compromised, and you won't have the extra strain on
suspension and brakes that come with a larger size.) Then do a search for what is available in that size. As someone said earlier, there probably won't be a lot of choice.
BTW are you sure the 16" rims will fit? With many modern cars you can't fit smaller than standard rims because of the size of the brakes. If you haven't already done so, I suggest you try the rims first before buying new tyres.
All the best,
Des
448312
Reply By: Kylie A - Tuesday, Mar 15, 2011 at 14:59
I have a series 2, Xtrail. It is an 2004 model.
We put Simex centrepedes on that (AT's). Went
well!
448321
