Reputable 4WD Mechanics in Adelaide
Submitted: Tuesday, Mar 08, 2011 at 13:44
Ligoland
Dear all,
We are travelling Australia in a 2003 Nissan Patrol 3.0L Diesel, and are coming up for a service.
Please could you let me know any reputable 4WD Mechanics in
Adelaide who know their stuff, do a great job and don't overcharge / rip you off.
Thanks all, and I look forward to hearing from you.
Kind regards
Ligoland.
Reply By: Member - Stephen L (Clare SA) - Tuesday, Mar 08, 2011 at 13:55
These guys know their stuff and do a great job:
http://www.alltrac4wd.com.au/
Give Peter a call.
447663
Follow Up By: Gossy - Wednesday, Mar 09, 2011 at 19:54
Agree with the above. I've had major work done there and very happy. One slight issue and fixed under warranty with no questions asked.
720096
Follow Up By: Fab72 - Wednesday, Mar 09, 2011 at 19:56
Yep...a vote for alltrac from me also.
720097
Reply By: jdwynn (Adelaide) - Tuesday, Mar 08, 2011 at 17:17
I use Nisscare at Royal
Park (recommendation from this site years ago now). Definitely fit your criteria - worth a visit. Cheers
447684
Reply By: Member - Lyndonc56.TAS. - Tuesday, Mar 08, 2011 at 17:26
Hi Ligoland,
Not sure about mechanics in
Adelaide, however, whomever you get to check out the Patrol, ensure they check the condition of your main Fan Blade as they are prone to cracking near the central outer ring between the fan blades themselves. This is caused by heat from the engine which tends to transfer through the fan clutch and eventually to the metal bolt on section of the fan. The metal heats up, and tends to cause the plastic/nylon covering it to shrink, thereby creating cracks and when you stop and the engine cools, the plastic/nylon fan tends to become brittle and when this reaches a certain point the fan can and sometimes does bleep ter. I know people that this has happened to, and they did not know what caused it. One hell of an expensive mess can be found under your bonnet in the middle of nowhere should this happen to you. Just be vigilant, and check for cracks at the end of a long days travel and you should be okay. I caught
mine and replaced it in time, as I had heard about this. Cheers Cashman.
447685
Follow Up By: Member - Lyndonc56.TAS. - Tuesday, Mar 08, 2011 at 17:34
Not sure what happened above as the word " bleep TER" was bleeped out! So I will say it again in two parts as I would not be surprised if it gets bleeped again. (Sha-tter)
719985
Reply By: anglepole - Wednesday, Mar 09, 2011 at 09:18
I have been taking my Patrol to Jarrett Nissan in
Adelaide Hills at
Bridgewater.
Very happy with them, and they are reasonable priced.
If you ring up a few days before and it is not a major service they will do it while you wait. Or you can take the bus to
Hahndorf for a look around or have a coffee
447746
Reply By: nickb - Saturday, Mar 12, 2011 at 02:12
I have used Rising Sun (Gepps Cross). He is good with gas and good prices(subaru expert too).
Colin Schubert (Modbury North) owns a fair few Patrols, don't have his number though. He is old fashioned and very knowledgable. A google search may come up with some answers.
447960
