coil rite air bags
Submitted: Monday, Mar 07, 2011 at 17:46
kjm
Hi there,
can someone please tell me what is the maximum pressure they put in their airbags when fully loaded and towing. We have a toyota landruiser 100s and tow a Kimberly Kamper limited Edition. When we had the airbags installed we were told the maximum is 20psi, but would like to put a little extra in, so any
feedback would be much appreciated.
Reply By: Hairs & Fysh - Monday, Mar 07, 2011 at 18:22
Hi kjm,
Don't have Coil rite, but I have Polyair.
Run 10 psi empty, 25 psi when towing the camper. Thats what they recommend. They are an "assist", not a lifting device.
With the Horse float on, I run20psi.
I also pump up to this pressure, I don't put 25 in them and then hang the camper on the back, this is what is recommended as
Hope this helps.
447598
Reply By: kjm - Monday, Mar 07, 2011 at 19:03
thanks for the info, I think the extra 5psi will be all that is needed.
447610
Follow Up By: Hairs & Fysh - Saturday, Apr 02, 2011 at 19:48
How did you go with the extra 5 PSI?
722570
Reply By: Shaker - Tuesday, Mar 08, 2011 at 12:09
Coilrite minimum pressure is 5 psi & maximum is 35 psi.
The also suggest pumping the bags up PRIOR to loading the vehicle & then releasing pressure to the desired ride height.
447656
Follow Up By: Shaker - Sunday, Apr 03, 2011 at 00:04
When you had the air bags installed they should ahve given you the installation instructions, as it is also the user guide!
722588
