How long will diesel keep for
Submitted: Sunday, Mar 06, 2011 at 14:59
Member - Damien L (Cairns)
Hi all,
How long will diesel keep for in jerry cans before it goes off and not suitable to use in an engine.
I have plastic and steel drums. Will it last longer in one type better than the other.
Damien.
Reply By: fisho64 - Sunday, Mar 06, 2011 at 16:36
It should keep for years if not contaminated.
447471
Reply By: GrumpyOldFart - Sunday, Mar 06, 2011 at 18:14
Damien
I keep 3000L of spare diesel on hand here in 1000L pods (Plastic container in a pallet size steel crate)
We use it as a reserve for our bowser as our underground tank is only 11000L and sometimes has trouble lasting between tankers.
Our fuel supplier advised that it should be good for 12 months before it starts degrading, I usually change it every six months.
Dru
| Remember
Life is short, Break the rules, Forgive quickly, Kiss slowly, Love truly,
Laugh uncontrollably, And never regret anything that made you smileLifetime Member My Profile My Blog Send Message |
447481
Reply By: trainslux - Sunday, Mar 06, 2011 at 19:57
Ensure your tank is clean.
Fill with clean diesel.
Add some chemtec, or nulon diesel treatment as per dose on bottle instructions.
If kept sealed will be fine for years.
Couple of things happen do diesel.
If there is water present, there is a chance of alge growth at the line of water/ diesel.
Diesel bugs feed on the sulphur, so in essence the low sulphur fuel can keep for longer.
Diesel can over time become cloudy with particulate.
Inspect ,and filter as required.
Your good to go.
I also add in 200:1 ratio some 2t 2 stroke oil for extra lubricity.
You can also use fuel stabilisers for long term storage.
Keep fuel out of extrem heat and sunlight, ensure containers are sealed, and your good to go.
Trains
Ps, winter grade diesel has a lower wax point, so if storing for long time, store winter grade as you can use it in either winter or summer.
447492
Follow Up By: Member - Damien L (Cairns) - Sunday, Mar 06, 2011 at 22:08
Thanks Fisho, Dru and Trains for your quick replies, I only want to store it for about 4 - 6 months.
I know now I can do this ta all,
Damien
719807
Follow Up By: Dave(NSW) - Monday, Mar 07, 2011 at 12:04
Damien,
Just make sure it isn't a blend with Ethanol as this will produce water when stored for awhile.
Cheers Dave.
719846
Follow Up By: Member - Damien L (Cairns) - Monday, Mar 07, 2011 at 17:53
thanks dave, i have always used
shell in the truck.
Damien
719889
