Running your diesel on water(HHO) and diesel fuel !!
Submitted: Friday, Mar 04, 2011 at 20:53
Michael ( Moss Vale NSW)
I was just looking at some U TUBE clips about running diesel engines on a normal diesel set up plus HHO, hydrogen made from half a litre of water in a
home made Hydrogen cell. It would be similar to running gas over diesel fuel with a diesel engine, which is fairly commonplace now but without the bulk of the LPG tank. The small
home made generator is made for a few dollars and draws about 4 amps and one guy claims he has increased his mileage from 15 mpg to 25mpg. Now that is a huge saving if touring. Most of the many different clips show a small tube, 8mm dia possibly, coming from the glass honey jar running into a hole drilled into the air intake. When you power up the cell with the cars battery, hydrogen is produced. Now im not suggesting anyone try this but it shows how easy you can make a fuel for basically nothing without taxes or intervention from Governments. Most of the clips on UTube look like an accident looking for a place to happen but im sure the process can be perfected to make it safe.. and the beauty of making HHO as you need it, the danger is probably less that driving an LPG vehicle..Have a look at the U TUBE Hydrogen car clips, its food fro thought!! It certainly beats the hell out of making bio fuel!! Clips are also there for petrol engines, its the same set up. regards Michael
| Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.Member My Profile My Blog Send Message |
Reply By: Muntoo - Friday, Mar 04, 2011 at 21:47
Yeah i know a fella who has made his own hydrogen set up.
Dunno how safe it is though.
447367
Follow Up By: Michael ( Moss Vale NSW) - Friday, Mar 04, 2011 at 22:23
I guess that was the point i was making. But there must be some potential.. Michael
| Patrol 4.2TDi 2003
719682
Reply By: Snoopyone - Friday, Mar 04, 2011 at 22:38
Friend of
mine had a setup in his car.
He started off saying it was marvelous.
Towards the end he reckoned if you blew what it made up your nose and lit it, it wouldnt blow your ears off LOL
Last saw the stuff in his rubbish bin.
He reckoned the glass jar ones simply dont make enough to work properly.
447371
Follow Up By: Michael ( Moss Vale NSW) - Friday, Mar 04, 2011 at 23:23
YOu are probably correct, there is a dry sealed cell that is more efficient! Michael
| Patrol 4.2TDi 2003
719688
Reply By: Batt's - Friday, Mar 04, 2011 at 23:05
Try www.hybridfuelcells.com.au I been researching HHO for about 12 months the most important thing I was told was don't use stainless steel systems they give off a very toxic poisoness gas titanium is dearer but no toxic gas
447372
Reply By: Member - Rodney B- Saturday, Mar 05, 2011 at 09:19
Myth Busters did a show on the so called fuel system improvers including Hydrogen cell as you describe.
Made no difference whatsoever and as stated above wouldn't pull the skin of a rice pudding.
Don't waste your time.
447387
Follow Up By: Michael ( Moss Vale NSW) - Saturday, Mar 05, 2011 at 22:07
I remember the Myth Busters show, they completely stuffed it up. I don think it is too far away from reality, but it will mainly be complementing your current fuel.. Michael
| Patrol 4.2TDi 2003
719733
Reply By: ob - Saturday, Mar 05, 2011 at 12:42
Maybe it would work better if a Hyclo(w)ne was used with it.
ob
447398
Follow Up By: Polaris - Saturday, Mar 05, 2011 at 18:02
LOL !!!
719723
