How Much Boost
Submitted: Wednesday, Nov 12, 2003 at 17:11
Member - Roger
Hi all,
What is the normal boost on the GU 4.2 Turbo?.
What is the max boost that can be safely used by this unit?
Lastly what is the most advantage boost for long range towing with this unit.
My unit has been tweaked to 10lbs is that ok.
RegardsDodg
Reply By: Truckster (Vic) - Wednesday, Nov 12, 2003 at 18:27
12-14psi I thought was std.. tweaked TO 10psi?
What is the max?? If you have a fuel aneroid, 20psi is ok, mate runs that has done for 80,000klms, doing comps and all...
My GQ TD42 with 10psi is ok, I want 14psi soon...going up 1psi made AMAZING difference
37047
Follow Up By: Goona - Thursday, Nov 27, 2003 at 17:35
tructster,
I believe 7 psi is standard and all GU's come standard with the aneriod
28664
Reply By: Geoff - Wednesday, Nov 12, 2003 at 18:41
I believe 7-8psi is std.
37050
Reply By: Mark from Getaway Portable Refrigerator Hire - Wednesday, Nov 12, 2003 at 19:25
Just following on from this, can you increase the boost on a 60 Series L/C Factory Turbo?
Pls no smart comments such as get the mouse to run faster etc.
Mark
37059
Reply By: Member - John- Wednesday, Nov 12, 2003 at 20:47
Hi Roger,
Geoff is correct - the standard boost is set at 8psi.
Cheers...
37071
Follow Up By: Member - Roger - Wednesday, Nov 12, 2003 at 23:24
John,
Glad to see your still looking.
RegardsDodg
26819
Reply By: Member - Eric- Wednesday, Nov 12, 2003 at 22:26
I would have thought .4 bar which is 7 to 8 pounds , 1o to 12 I think would be safe
Venus Bay
37087
Reply By: charlie - Friday, Nov 14, 2003 at 10:01
How do you turn the boost up on factory turbo's such as an 80 series direct injection Turbo?
37278
Reply By: chrisfrd - Saturday, Nov 15, 2003 at 22:59
I've just completed the electrical system of a GUIII 4.2Tdi that is running twin M24's producing 26PSI into custom intakes/exhausts.... It bleep ing SCREAMS!
This is due to some sound engineering.. Firstly, the computer system (a haltech!) watches the fuel intake through a flow sensor on each injector, then it watches the exhaust gas tempurature, ensuring that it maintains average temps not exceeding 530 degrees Celsius. In addition to this, it also has a Co2 sensor and TPS to monitor how rich the engine is running...
What I'm trying to say is that you can get that engine to do anything... If you have the moolah!
Don't just up the boost by getting the spanner out.... Get the boost adjusted up, then get the fuel mixture readjusted correctly by diesel engine experts with proper equipment to measure temps and mixes. Then you will have a truck that can run good boosts on the same gear SAFELY!
Chris
37441
