Slide on campers, How stable is your vehicle with these on the back?
Submitted: Thursday, Mar 03, 2011 at 20:01
ThreadID: 84762 Views:6607 Replies:8 FollowUps:6
I followed a ute with what looked like a high rise camper on, through a round about
today, and was surprised at the way this thing got a huge lean happening at a relatively slow speed!, Quiet a concern actually, its made me wonder about the safetey aspect of these units?, I know you would get used to them but on unknown roads ,Jeeeez!!, you would have to watch your self on corners, or might end up camping in someones paddock upside down,...lol.
Cheers Axle
Reply By: Member - Serendipity(WA) - Thursday, Mar 03, 2011 at 20:10
Yeah Axle, the slide on campers pretty well max out the GMV when fully loaded. I have added airbag suspension which helps to fix the body roll you get with a heavy load on the back.
I don't know which is worse - a heavy slide on camper or towing a heavy camp trailer.
David
AnswerID: 447251
Follow Up By: Axle - Thursday, Mar 03, 2011 at 21:43
Suspension area was what crossed my mind, if i were to put one on the landy,
or what ever if it had coils.
Axle.
FollowupID: 719568
Reply By: _gmd_pps - Thursday, Mar 03, 2011 at 21:03
not a problem with the right vehicle!
have fun
gmd
AnswerID: 447265
Follow Up By: Axle - Thursday, Mar 03, 2011 at 21:37
Good looking unit GMD, But surely the fuel consumption must be a issue, if nothing else.
cheers Axle.
FollowupID: 719567
Follow Up By: Member - Joe n Mel n kids (FNQ - Friday, Mar 04, 2011 at 00:32
look good to me, it "looks" like it would handle well also, some i have seen just one look at and it makes me shudder, i have never driven one so cant confirm it but to me if it looks like it would be horrible then it most probally will be ....
I suppose if fuel comsumption was an issue then you would not have purchased it and simply stayed at home, see some of the tiny little cars towing hugh vans all in the name of fuel economy ...why i ask, why ???? hahahah
fuel may be an issue for me, after i fit axel No 3 on the cruiser, why ??? cause i can, dont care about fuel..
FollowupID: 719577
Follow Up By: _gmd_pps - Friday, Mar 04, 2011 at 01:02
Haha .. no clue right ?
It drives like a charm and fuel is less than a Landcruiser V8.
Why do you all think that these truck use so much fuel ?? no idea right ?
with the tunes I run I get just a bit over 400hp. Even if it would not be as economical as it is I could not care less about fuel consumption for the comfort I get. If you have never driven one you cannot even guess what it is like ..
have fun
gmd
FollowupID: 719579
Follow Up By: Member - Joe n Mel n kids (FNQ - Friday, Mar 04, 2011 at 19:44
take comfort and room over fuel any day....
What motor is it ?????
FollowupID: 719659
Reply By: Wilko (Parkes NSW) - Thursday, Mar 03, 2011 at 21:03
Hi Axle
Had an older style on my Rodeo for a while. It was heavy 700kgs and had a high centre of gravity.
It was unnerving to drive but was ok after a while. I sold it cause it was too high on the ute and would catch the wind blowing the fuel economy.
Best part of it was I could tow the boat
AnswerID: 447266
Reply By: Tonyfish#58 - Thursday, Mar 03, 2011 at 21:13
No issues if you keep them low like mine & throw on a set of Load assist air bags
Cheers Tony
AnswerID: 447271
Reply By: Member - Murray R (VIC) - Thursday, Mar 03, 2011 at 22:12
Hi Axle
My set up is the same as David & Tony's and have no problems when set up properly. GMD's is set up properly also, big slide on, big ute, but slide ons like GMD's on smaller utes makes you wonder about their stability.
Murray
Another Mexican
AnswerID: 447281
Follow Up By: Axle - Thursday, Mar 03, 2011 at 22:23
It Did not look right Murray, It was a hilux non 4by, from what i could see.
Axle.
FollowupID: 719574
Reply By: Farmboywa - Thursday, Mar 03, 2011 at 23:22
G'day Axle, the first slide ons, to my knowlege were made to fit into the first Falcon utes with the tail gate down. They were actually lifted on either side with independently operated hand winches on a vertcal tripod mounted steel pole and the ute was then reversed under the camper. The original Falcons were built to carry the 700kgs. I still own one which I bought for $1000.00 around 1978 and have carried it on a Holden one tonner with air shocks and a Datsun 1tonne with air shocks. The Datsun certainly wallowed on the corners. I now have it mounted in a braked tandem trailer.
AnswerID: 447286
Reply By: Member - Geoff M (VIC) - Friday, Mar 04, 2011 at 07:44
Hi Axle,
We have a slide-on camper and one of the main considerations was the weight and height. Many of the slide-on's on the market (including one of the most popular one) are unable legally to be carried (above GVM) by the majority of utilities on the market, once you fill the water tank and load up some supplies.
Also there have been plenty of threads on the problems with chassis break's on ute's (all makes equally affected) and the compounding effect airbags can have on this.
We have upgraded our suspension and try hard to keep the weight down - unlike several other setups we have seen during our travels.
If you are considering or have a slide-on consider your weight, GVM, suspension setup and selection of slide-on. There are many good options out there for slid-ons, and there are many benefits such as towing a boat and access to 4WD locations.
Cheers, Geoff
AnswerID: 447302
Reply By: lizard - Friday, Mar 04, 2011 at 10:19
We have a slide on (Ezi-up from C & M Campers) on our GU .... ute has HD springs & Polyairs as well as gas shockies (bought for CSR) .... doesn't wallow - actually sits nice & level & smooths the ute ride nicely . Had chassis reinforced with the ATOC kit - and a GCM upgrade .
AnswerID: 447311
