GQ Patrol air con wasn't working right and now is frezzing findout how
Submitted: Thursday, Mar 03, 2011 at 08:54
ThreadID: 84747 Views:9726 Replies:4 FollowUps:2
hi, we have a GQ patrol and have always had trouble with the aircon not working the way we thought it should, we have had it regassed and a new belt fitted and only works a bit sometimes and never what we would think it should and the fan didn't seem to blow out much air. so recently hubby thought he would take out the fan to see if it needed the blades cleaned as it was also a bit noisy, so popped out the glovebox and took out the fan which did need a clean, he noticed the bird cage (or thermostat cage) and this was covered in fluff and bits of hair so he removed that to clean it, then looked in behind where the cage was and there an area that was chocker full of leaves, fluff and bits, the fins on the evaporative cooler were also clogged up (about 90% clogged) and looked corroded, so got all the leaves and bits out and used a bit of wire with a small hook on the end to pluck out the bits from the fins, we used the cleaner to suck up most of the bits and left it open with a heater blowing on the fins to dry it out, then used a hard toothbrush taped on a stick to clean off the rest of the fins then vacced it out again and put it back. the difference it made is totally amazing, our GQ is now an ice block it now works better than we ever thought it would, so we thought we would share this with others as it a relatively easy and no expense job with great results.
chris.
Reply By: Member - Tricky Dicky (NSW) - Thursday, Mar 03, 2011 at 09:47
thanks for that info, i will check mine out this weekend as its not really as cold as i would like
Dick
AnswerID: 447189
Follow Up By: gonebush SA - Thursday, Mar 03, 2011 at 11:32
our fan speed now on the 1st setting is more than we were geting on the 4th setting, hope it works out for you
chris.
FollowupID: 719501
Reply By: Member - MUZBRY(Vic) - Thursday, Mar 03, 2011 at 12:30
Gday
Now that my wife has seen your writings, i now have a job that has to be done .
Thanks Chris
Murray
AnswerID: 447202
Reply By: Member - Toyocrusa (NSW) - Thursday, Mar 03, 2011 at 20:14
Hi Gonebush. The "birdcage" part you are refering to is called the Evaporator. It has cold refrigerant passing through coils on the inside and cools the air passing through the fins on the outside. I have seen these items really badly matted with dog/animal hair from owners carrying their pets in the car with them, to the extent that there is even a bad smell from the hair. If you can fit a "Cabin Filter" to the air intake side this will help to alliviate the problem in the future. Cheers,Bob
AnswerID: 447255
Follow Up By: gonebush SA - Friday, Mar 04, 2011 at 15:16
hi, the bird cage part i'm talking about isn't the evaporator, it's a small cage like thing and inside it there is a (controller of some sort, i think it is). the fins i am talking about are on the evaporator.
chris
FollowupID: 719637
Reply By: Member - Ray (QLD) - Thursday, Mar 03, 2011 at 21:53
Oops. showed the warden this post, now I have a job to do as well.
Ray
AnswerID: 447277
