caravan water filters
Submitted: Wednesday, Mar 02, 2011 at 20:46
ThreadID: 84733 Views:3077 Replies:4 FollowUps:1
Hi all, just wondering what water filters are best in line under the sink in caravans.
I have an ever pure the water in it whent black and smelly whilst sitting un used for a period.
i feel i need to drain it when not in use.
Any ideas?
Garny
Reply By: SPRINT-GTO - Wednesday, Mar 02, 2011 at 23:07
Try Freshly Squeezed Water Co they have offices in Sydney and Brisbane.
We have a system in van and a larger system on the 3 5000gal water tanks on our rural property--very happy with results.
AnswerID: 447171
Reply By: Member - Ann D (WA) - Thursday, Mar 03, 2011 at 12:50
Have a look at B.E.S.T filters,have used them on the hose to water tank,for a number of years now.
Ann D.
AnswerID: 447205
Reply By: Lucko - Thursday, Mar 03, 2011 at 13:46
We just use the 10" activated charcoal cartridges under the sink (all water is filtered as it goes into the van tanks). Quite reasonably priced on eBay. About $60 for the housing and around the $12 mark for filter cartridges. We've found the trick is, when filters aren't going to be used for some time, remove them, seal them in those resealable sandwich bags and store them in the fridge. The low temps discourage mould etc. from growing. Hope this helps.
Mark
AnswerID: 447212
Reply By: Member -Dodger - Thursday, Mar 03, 2011 at 17:26
We have used the everpure filters for years without a problem.
I suspect that the filter may have been close to its use by date when you stored the van, resulting in the odour.
I would have simply changed the filter and carried on.
Our van is never stored for more than a month so this may be why we have never had this trouble.
If I were to store the van for an extended period i would simply disconnect the cartridge and empty it if it can be done.
Cheers Dodg.
AnswerID: 447234
Follow Up By: garny - Thursday, Mar 03, 2011 at 22:18
Thanks for the info unfortunately we are not on the road full time
will endeavor to empty filter and store
Garny
FollowupID: 719573
