Hot tips on home servicing of caravan 3 way fridge.
Submitted: Monday, Feb 28, 2011 at 10:25
Andrea11
Good Morning everyone,
Would anyone be kind enough to offer some advice. I currently have an electrolux RM2310 90 litre fridge that works ok but I think is in need of servicing. We are not sure how to do this so if anyone could give us some much needed advice it would be greatfully appreciated. We are wanting to get the caravan all sorted before our camping season kicks off at
easter.
Thanking you all
Andrea
Reply By: Member - res.q.guy (Vic.) - Monday, Feb 28, 2011 at 11:13
Reply By: vk1dx - Monday, Feb 28, 2011 at 11:24
For something as important as a fridge why not get someone to do it for you? Put it this way, would you do your own fridge at
home? I wouldn't.
I understand it costs. But . . . .
446844
Reply By: Andrea11 - Monday, Feb 28, 2011 at 11:52
Thanks for your replies. The links were helpfull so thanks for those. I have found a company that will do the servicing for us next week. So thanks again.....
Andrea
446852
Follow Up By: vk1dx - Monday, Feb 28, 2011 at 12:38
No worries. And thanks for dropping back.
So many ask a question and then just disappear without so much as a . . . . .
719213
Follow Up By: Andrea11 - Monday, Feb 28, 2011 at 13:28
I have noticed that Phil. I think it's rude and wonder where good manners have disappeared to these days.
Andrea
719220
Follow Up By: vk1dx - Monday, Feb 28, 2011 at 13:40
Now lets not go there.
Have a lovely trip. We got the second fridge in preparation for some Australian desert trips. The first being the
Simpson Desert. Hopefully in May if its not flooded!!!!!.
Cheerio
719221
Reply By: B1B2 - Monday, Feb 28, 2011 at 13:02
G'day Andrea,
1st off I would be testing the fridge overnight . If you can plug it in to 240v and put a thermometer in the cool side and the freezer side.
If this gives - 15 ish and +4 it is ok on 240 and will probably not be short of ammonia.
Then try it on gas. if both of these tests are ok, now for the 12 volt
test. it should hold the temp when travelling, if it doesn't it could be due to your wiring, and too much volt drop.
The history of the unit would be useful, did it work ok previously?
The unit works by heating the ammonia and separating it to Hydrogen. As you have 3 heating methods you can diagnose if one is faulty. if all 3 are no good it could need a recharge, which is very expensive unlike a compressor refrigerator.
If you have used these fridges before you will know it will perform better if chilled down overnight before loading it.
The more diagnostic you can do yourself the better.
Hope this helps,
Bill
446860
Follow Up By: Andrea11 - Monday, Feb 28, 2011 at 13:27
Thank you Bill we will do that testing tonight. The fridge is plugged in to power as we speak.
Kind regards Andrea
719219
Follow Up By: Tenpounder (SA) - Monday, Feb 28, 2011 at 17:14
Hi there. Mt comment to Bill is that if my 3-Way gave -15 and +4, then the first thing I would do is to throw away the thermometer and buy a decent one! Unless, of course, you are testing at an ambient temp of about 15 degrees. Ahint of sarcasm, perhpas, but also a big dose of personal experience!
719249
Follow Up By: B1B2 - Monday, Feb 28, 2011 at 20:06
G'day Chris,
-15° in the freezer and +4° in the fridge , I would be happy with that.
Just trying to help not confuse.
Bill
719268
Reply By: Neil & Pauline - Monday, Feb 28, 2011 at 13:32
My experience is with kero fridges which are the same thing. I found the biggest issue reqired as a service is to clean all the back fins etc. If the gas and electric gets it down to temp then all there is to do is cleaning.
Neil
446864
Follow Up By: Andrea11 - Monday, Feb 28, 2011 at 15:49
Thanks for the information Neil. Much appreciated.
719235
Follow Up By: Roughasguts - Monday, Feb 28, 2011 at 15:54
I agree, get a paint brush and clean all the dust off the condenser and pipes to keep the moisture and rust hopfully away from the pipes and aids in the cooling as
Apart from that maybe a coat of paint with a spray can if the pipes are rusting theres nothing else to do. It seems the condensor will rust anyway but from the inside under the insulation where you can't see it, it starts off as pitting the alloy pipes until theres a hole that lets the gas out! then big bucks to replace the cooling unit.
Cheers.
719237
Follow Up By: Andrea11 - Monday, Feb 28, 2011 at 16:55
Thanks Roughasguts...
719243
Reply By: Member - Bruce C (NSW) - Monday, Feb 28, 2011 at 18:27
Hi Andrea,
I had a problem last year with our 3 way frig in the van and it turned out to be mud wasp nests in the flue pipe.
This usually only occurs if you live in or near a rural area.
The solution is to clean out the flue with a piece of wire, albeit very carefully as you may damage something if you go at it a bit rough.
Otherwise the previous posters would be on the money.
As has been said, if all these tests fail then it is a trip to the fridge Mechanic.
Cheers, Bruce.
446903
Follow Up By: Andrea11 - Monday, Feb 28, 2011 at 19:09
Thanks for the advice Bruce...
719262
Reply By: Andrea11 - Friday, Mar 04, 2011 at 20:02
Hello to you all,
I just wanted to update you on our fridge. We took it out and had it serviced proffessionally. Today we got it back with a very good result from the testing which was on gas on a 34 deg day yesterday the fridge cooled too 4 degs fridge and freezer -15.5...So we are happy with that. On electricity the fridge was 1.7 deg and freezer -18.5 again we are happy with that.
Thanks again for all the wonderful advice you took the time to give. We really appreciate it.
Have a terrific weekend
Andrea
447360
