Plugs for Codan 9350 antenna
Submitted: Friday, Feb 25, 2011 at 16:48
Nev (TAS)
Hi all,
I would like to buy right angled plugs for my HF 9350 antenna. This would help tidy it up and provide less stress on the cables. One cable is the control cable (5 wire), and the other the antenna co-ax. Would appreciate any leads, thank you.
Rgds
Nev
Reply By: Nev (TAS) - Friday, Feb 25, 2011 at 16:53
5 wires but a 6 pin mil connector with one unused pin.
446539
Follow Up By: Member - Rod N (QLD) - Friday, Feb 25, 2011 at 20:39
As said the control connector is a military spec connector. The rear backshell (clamp) should be available. Do you know anyone in the RAAF?
718957
Reply By: Member - Graham H (QLD) - Friday, Feb 25, 2011 at 18:54
Have you asked Codan if they have them or where to get them.
446547
Follow Up By: Nev (TAS) - Friday, Feb 25, 2011 at 19:42
Yes I have Graham, still waiting a response.
718942
Reply By: Mike DiD - Friday, Feb 25, 2011 at 19:16
The Coax Connector is readily available, or you could just add a PL-259 plug (front) to SO-239 (rear) right angle adaptor - $9 from
http://www.andrewscom.com.au/site-section-08.htm
These connectors have NIL waterproofing so you need to make sure you seal every joint with CoaxSeal or SelfAmalgamating tape.
The Control Cable connectors are very specialised - I'm not sure if you can get Right-Angle Plugs.
446550
Follow Up By: Nev (TAS) - Friday, Feb 25, 2011 at 19:46
Thanks for that Mike DiD, I will get onto them asap.
Much appreciated.
718944
Follow Up By: Mike DiD - Friday, Feb 25, 2011 at 20:48
Make sure you tighten them up really
well !!!
They depend on being tight for good contact of the outer connector - unlike BNC or N-type which make perfect contact as soon as you push them together.
718959
Reply By: Member - Mark E (VIC) - Friday, Feb 25, 2011 at 22:07
Nev,
The coaxial cable connector is simply an SO239 (?) from memory with a PL259 plug on the end of the coax. A right angle connector is easily available from most good communications shops.
The 9350 control cable connector, both male and female and made by
Amphenol . Their website has a number of catalogues to download and they're in their somewhere.
I'm not too sure whether you will get a right angled connector for this plug, but it's worth a look.
What I did was to rotate the antenna in a particular direction to 'protect' these cable and connectors and after many years of use have had no trouble with them. I do however use a liberal amount of self amalgamating tape to waterproof these connectors and I also feel this helps with the 'strength'.
All the best....
Mark
446565
Follow Up By: Nev (TAS) - Saturday, Feb 26, 2011 at 18:31
Thanks Mark.
good info.
Nev
719035
Reply By: Member - Alastair D (NSW) - Saturday, Feb 26, 2011 at 08:21
Liquid PVC available in a small can from Jaycar is a good way to waterproof these connectors and other things too.
446581
