A Little Info on the New VW Amarok
Submitted: Monday, Feb 21, 2011 at 07:56
ThreadID: 84507 Views:6380 Replies:6 FollowUps:20
VW Amarok
I am not sure if you click on this link it will come up.
Reply By: Isuzumu - Monday, Feb 21, 2011 at 08:00
Well that did not work, some one might be able to help me here.....I received this as an attachment on an e-mail as a pdf file so is there anyway I can copy that to here?
AnswerID: 446132
Follow Up By: Road Warrior - Monday, Feb 21, 2011 at 13:13
Save the PDF file to your desktop or whatever, then go to a website like http://www.mediafire.com/ and upload the PDF. Copy the link you are given from that site and paste it here.
FollowupID: 718472
Follow Up By: Member - Niss42 - Monday, Feb 21, 2011 at 13:15
Try this link:-
http://www.volkswagen-amarok.com.au/
Barry
FollowupID: 718473
Follow Up By: Isuzumu - Monday, Feb 21, 2011 at 13:17
Hi Barry, no this one I have is a full specification sheet on it.
FollowupID: 718475
Reply By: Isuzumu - Monday, Feb 21, 2011 at 14:07
Type
4 Cylinder, DOHC, 16 Valve
Installation
Inline installation
Construction materials
All alloy
Capacity, litres/cc
2.0 / 1,968
Bore x Stroke /
Compression ratio
81.0mm x 95.5mm /
16.5:1
Maximum power, kW @ rpm
120 @ 4,000
400 @ 1,500-2,500
Maximum torque, Nm @ rpm
Fuel system
Common Rail Direct Injection
Induction type
Twin-turbochargers
Intercooled
Yes
Emissions standard
Euro 5 with Diesel Particle Filter (DPF)
Fuel type
Diesel
Fuel tank capacity
80 Litres
Battery
480 Amp 95Ah Transmission
Transmission – manual
6 Speed Manual
Driven wheels
Rear wheel drive / Selectable 4MOTION Wheels and Tyres Amarok Amarok Trendline Amarok Highline
Wheels
Steel
6.5J x16
Alloy “Taruma”
6.5J x 16
Alloy “Durban”
7.5J x 18
Tyres
205 R16 C 110/108T
245 / 70 R16 111T
255 / 60 R18 112T
MY11 / December 2010 / PW-A
Fuel Consumption – ADR81/02 Comb / Urban / Ex Urban • CO2
Manual, Litre/100km • CO2
7.7 / 9.5 / 6.8 • 203g/km
4MOTION, Litre/100km • CO2
7.9 / 9.7 / 7.0 • 209g/km
Suspension & Steering
Front axle
Transverse link with A-frame arm double wishbone and anti-roll bar
Rear axle
Multilayer rigid axel with leaf spring and stabiliser bar
Steering
Rack and pinion power steering
Turning Circle
12.95 m Brakes
Front brakes
303mm Disc brakes
Rear brakes
292mm Drum brake
Brake systems
ESP, OFFROAD ABS, ASR, EDL and Hill Holder Weights
GVM, kg
3,040 (optional 2,820)
Towing capacity, braked / unbraked
2,800kg / 750kg
Towing downball load
280kg Amarok Amarok Trendline Amarok Highline
GVM 3,040
Standard (Heavy Duty)
GVM 2,820
Optional (Comfort Suspension)
Tare weight (includes driver)
1,807
1,828
1,828
Payload 2820 Comfort Suspension
937
916
916
Payload 3040 (Heavy Duty Suspension)
1,157
1,122
1,122 Dimensions
Length, mm
5,181 (Amarok) 5,254 (Trendline and Highline)
Width, mm
1,944 (2,228 including mirrors)
Height std
1,834
Wheelbase, mm
3,095
Ground clearance mm
265 (249 with underbody protection) Amarok Amarok Trendline & Highline
Entry angle
28º
28º
Departure angle
28º
23.6º
Ramp angle
23º(21.4º with 4WD)
23º(21.4 with 4WD)
Wadding depth
500mm Cargo Area
Rear tailgate width, mm
1,411
Rear tailgate height, mm
508
Load volume, m2
2.52
Length mm
1,555
Width at widest point mm
1,620
Width at wheel arch mm
1,222
Height from ground mm
780 Warranty
Vehicle
3 Years, Unlimited km
Paint / Corrosion
3 Years / 6 Years
Road side assistance
The only way I could do it hahahaha
AnswerID: 446167
Follow Up By: Isuzumu - Monday, Feb 21, 2011 at 14:29
VW say it is going up against the Hilux, so I did a bit of resource and found a couple of things different from the Hilux...
It is 109mm wider than the Lux, has 249mm ground clearance, Toyota says the Hilux is only 210mm does not seem right.
Also of interest it is coming out with two different rear suspensions, also a rear diff lock and of course full time 4WD.
They are being released on the 12th March and that is when we will find out how much they cost, probably a lot more than I can afford hahaha
FollowupID: 718481
Follow Up By: Member - Graeme W (NSW) - Tuesday, Feb 22, 2011 at 13:19
Hi Bruce,
It appears that prices have been announced today:
Amarok article
Volkswagen Amarok prices at a glance
Amarok 2WD: $33,990
Amarok 4WD: $43,990
Trendline 4WD: $47,990
Highline 4WD: $52,990
Ultimate 4WD: $58,490
Graeme
Lake Eyre 2011
FollowupID: 718606
Follow Up By: Isuzumu - Tuesday, Feb 22, 2011 at 13:22
Thanks for that Graeme, does not look all that bad.
FollowupID: 718607
Reply By: palmy - Monday, Feb 21, 2011 at 15:11
Wonder what the target market is, if it's trades then fine, but if more for personal use (which is where VW seems to fit to me) coils and rear disc would be preferred. I'll never ever buy a leaf/drum brand new vehicle again. (had current model dual cab)
AnswerID: 446175
Follow Up By: BrownyGU - Monday, Feb 21, 2011 at 15:50
mmmmmm, Leaf & drum is a disapointment!
FollowupID: 718489
Follow Up By: Shaker - Monday, Feb 21, 2011 at 16:53
Yet for some reason, we accept drum brakes on camper trailers & vans.
FollowupID: 718505
Follow Up By: palmy - Monday, Feb 21, 2011 at 20:23
True, but to me, not as important.
FollowupID: 718532
Follow Up By: Shaker - Tuesday, Feb 22, 2011 at 11:27
Maybe not, but it is probably braking more than an individual axle on the tow vehicle.
FollowupID: 718595
Reply By: Member - Phil G (SA) - Tuesday, Feb 22, 2011 at 08:14
People buy VW's because of the quality and engineering. So it may attract different buyers than the Hilux market. I'm expecting tradies and families will go for it, miners won't.
I've owned lots of Jap 4wds but last week bought a VW Tiguan (small 4wd) to replace an Xtrail. It feels like quality and drives so well. I expect the Amarok will be well above the Hilux in this respect.
Downsides at this stage is they are only available in manual.
The Amarok also has a diesel particulate filter (you need VW507.00 spec synthetic oil which cost me $123 for 5 litres, and the DPF can block up and costs $5000 to replace).
AnswerID: 446236
Follow Up By: Member - Phil G (SA) - Tuesday, Feb 22, 2011 at 08:20
Heres a video commercial from Argentina (the Amarok is built in Argentina)
FollowupID: 718579
Follow Up By: Isuzumu - Tuesday, Feb 22, 2011 at 08:32
One of my first questions when I go to look at them will be, how much for the servicing? Will probably be in the BMW class which will put a lot of people off I would think.
Some thing that will hurt for me, paying some one else to do the servicing. Was probably in the 70's I owned a new car, so not looking forward having to go back to the dealer for it.
FollowupID: 718580
Follow Up By: Isuzumu - Tuesday, Feb 22, 2011 at 08:34
Wander if they will let me do that when I take one for a test drive hahahahaha
FollowupID: 718581
Follow Up By: Member - Phil G (SA) - Wednesday, Feb 23, 2011 at 13:01
Bruce,
Servicing costs are very consistent across VW models - typically only done yearly or 15,000k. The oil is synthetic and expensive, but the cartridge oil filters are $20 each, and fuel filters $66 every 60k. I doubt they will have a timing belt as VW are using Timing Chains more often now.
Most models are about $300 each service until 60k.
FollowupID: 718714
Follow Up By: landseka - Wednesday, Feb 23, 2011 at 13:15
You can haggle and get $1000.00 off new price if you buy the one used for the ad as a demo model. lol
FollowupID: 718715
Follow Up By: ben_gv3 - Wednesday, Feb 23, 2011 at 13:16
And how much are services after 60k?
FollowupID: 718716
Follow Up By: Isuzumu - Wednesday, Feb 23, 2011 at 13:19
Thanks Phil, I will be keep to find out if they are going to bring it out in a cab chassis as I do not want a tub on the back.
FollowupID: 718718
Follow Up By: Member - Phil G (SA) - Wednesday, Feb 23, 2011 at 18:14
Ben,
The biggie for our Tiguan is the 105,000k service which includes timing belt and tensioner - service is about $1500. And I think there's the odd service that is $600 because it includes brake fluid changes and haldex fluid changes. But the Haldex fluid change intervals are being reduced with the newer units.
FollowupID: 718734
Follow Up By: Isuzumu - Wednesday, Feb 23, 2011 at 20:36
I read some where to day they will come out with an alloy tray, so that's good for me.
FollowupID: 718761
Reply By: Mark S (cns) - Wednesday, Feb 23, 2011 at 14:27
Ok - enough speculation
read here
VW Amarok, including pricing
There ya go!
AnswerID: 446372
Follow Up By: Isuzumu - Wednesday, Feb 23, 2011 at 18:33
Thanks for Mark
FollowupID: 718739
Reply By: Member - geelong gypsies - Sunday, Mar 06, 2011 at 19:48
I saw a pair of them up close today at some proving grounds. I think it was set up for a demo to dealers. Not a bad looking rig.
AnswerID: 447490
