Sunday, Feb 13, 2011 at 17:34
Peter, funny you shoud mention that. Firstly, I'd say the Bote is designed for mid to quiet waters, lakes, rivers, bays and mild seas. Having said that it handles a swell reasonably
well. The flex of the hull means it doesn't tip around as much as a tinnie (takes some getting used to at first, though). I think however that the flex makes it spin around in a quatering sea more than a tinny. As for the low bow, yes it does let a bit more
water over the top sometimes, though not that I've noticed much difference from most tinnies.
The reason I said funny you should mention this, while taking down the boat today I was thinking about how narrow it is in the nose (bow). Without the plate the bow is normally narrow and I copied my plate from one a guy in the Netherlands made. Today it struck me the inward tilt of the sides at the bow don't do the Bote any favours when it comes to deflecting waves. It also makes the Bote look a bit odd. I've decided to make a new bow plate, much wider than the original (600mm at the base as opposed to 400mm). This has a number of advantages- it will deflect spray better; it will give the bow a better profile; it will give a larger area in the front for storage and fitting gear onto the plate. The last benefit is that when making the plate I had to mess around chamfering the sides to suit the angle of the front. This also meant the flat plate did not sit
well into the alloy channels. By making the plate wider it will straighten out the flare at the front and make it sit better. I'll put a piece of foam underneath to fill the "hole" at the front. Wish I'd thought of that before making a new plate last week!
If you are thinking of the Bote as a replacement for your half cabin you may be disappointed. As a replacement for a tinnie however I can't recommend them highly enough.
Mark
717568
