Diagnosing Help Please
Submitted: Saturday, Feb 12, 2011 at 12:14
TensionWrench
My 100 Series LC has been sitting for awhile due to a lot of work travel and has developed a concerning noise. It is a constant low pitch metal on metal squeal which continues as I drive along at any speed. If I turn left ibrakes it continues if I turn right the noise disappears until I am heading straight again.
I also had to tow the van the other day and under heavy braking I received 2 clear and distinct heavy clunks from the right wheel. The rotors have done 215K and the last 18k have been towing. I have viewed the rotors they seem ok but I know they have been machined once. I was going to replace rotors and brakes. Thoughts?
Many Thanks
TensionWrench
Reply By: Member - Graham H (QLD) - Saturday, Feb 12, 2011 at 12:41
Probably the tell tales telling you the pads are shot.
445157
Follow Up By: Member - Graham H (QLD) - Saturday, Feb 12, 2011 at 12:45
To clarify further they have little tits that rub on the rotors when the pads are worn down
They squeak and let you know to put hand in pocket LOL
717417
Follow Up By: Member - Christopher P (NSW) - Saturday, Feb 12, 2011 at 22:09
x2
squelly brakes equals pads, i did have a worn pad indicator brake on me, ended up throwing it out. because you can't get them generally.
717467
Follow Up By: Member - Graham H (QLD) - Saturday, Feb 12, 2011 at 22:16
Or stones trapped on the calipers.
Change the pads earlier save the tits LOL
717471
