Inline fuse and Anderson Plug
Submitted: Tuesday, Feb 08, 2011 at 19:57
ThreadID: 84213 Views:3576 Replies:4 FollowUps:2
Have just purchased a Codan NGT and note that the cables provided do not contain an inline fuse and directions state connect directly to battery.
Do you need an inline fuse if you are only running the Codan from the connection?
Reply By: Member - Tezza Qld - Tuesday, Feb 08, 2011 at 20:40
I ran my HF direct from the radio to an anderson plug [for easy removal] and from there to a resettable circut breaker mounted close to the main battery.
An in line fuse would do the same thing but keep it as close to the battery as possible.
Cheers Teza
AnswerID: 444694
Reply By: MattR - Tuesday, Feb 08, 2011 at 21:01
To a first approximation, if the cables that go to the Codan are not as thick as the main battery cables on your vehicle (the big fat ones from battery - to body and battery + to starter), then you need a fuse. Like Teza said, put the fuse as close to the battery as you can manage.
When any wire is carrying current, it heats up; smaller wires heat up faster. The idea is to stop the wire from getting so hot that it melts off its insulation and/or starts a fire. A properly sized fuse will blow before the wire gets hot enough to be dangerous.
Probably the reason the directions say to go right to the battery is that radio transmitters are notoriously "spiky" in current draw... they can be loafing along at half an amp and then you key the microphone and they jump up to 8 amps or more. If the radio is on the far end of lots of switches and relays and wire and stuff, there will be a lot of voltage drop and the radio won't work very well; it can actually affect how clear your transmissions are. Wiring direct to the battery avoids this. But you still should use a fuse.
Matt R.
AnswerID: 444696
Reply By: Member - Graham H (QLD) - Tuesday, Feb 08, 2011 at 21:10
When I got my NGT it had a great big MAXI fuse that came with it and about 6 metres of heavy cable to run it with special connectors on the end to connect to the black box.
Better check why it isnt there
It actually had a fuse like a house fuse that sat into two grooves in the housing Was a massive thing that had a screwhole in the bottom to mount it on the body near the battery.
Was in original box so I guess it was factory
AnswerID: 444697
Follow Up By: Member - Graham H (QLD) - Tuesday, Feb 08, 2011 at 21:36
The cables on mine were much heavier than 6 mm cable
Was really substantial, filled up the hole in the fuse casing anyway.
Was twin cable as I said with the end for the radio already on it.
FollowupID: 716846
Reply By: coombesplo - Thursday, Feb 10, 2011 at 18:42
Thanks all found the fuse it is massive the cable that came with the NGT is also substantial so thanks for all the responses guys.
Dave
AnswerID: 444967
Follow Up By: Member - Graham H (QLD) - Thursday, Feb 10, 2011 at 19:35
Yep they pack them away neatly in the box dont they.
FollowupID: 717164
