Camera connections
Submitted: Tuesday, Feb 08, 2011 at 18:40
Member - John B2 (WA)
I've just been attempting to install and connect a Hema reversing camera to a Hema 5 gps.
Neither I nor my Auto electrician can make it work.
There does not seem to be adequate detail provided in the "instructions"
Any body else had any problems?
Reply By: ABR - SIDEWINDER - Tuesday, Feb 08, 2011 at 18:49
When I tested it you need to open the options menu right in the beginning when you power up the hema.
You can then select the av input.
Once this is done as soon as the hema senses the av signal the reverse camera will show on the screen.
Derek from ABR
444677
Reply By: Member - Graham H (QLD) - Tuesday, Feb 08, 2011 at 18:50
Most arent hard trigger from reverse earth it and plug it in to the headunit.
444679
Reply By: poppygrumps1 - Wednesday, Feb 09, 2011 at 07:28
If you have the power hooked up directly to the reversing light there is not enough power until you have the engine running. At least that was my problem
444736
Follow Up By: Member - Graham H (QLD) - Wednesday, Feb 09, 2011 at 09:02
Something wrong there I have a switch so
mine can be on all the time and it goes whether car running or not.
716879
