Can't access profile
Submitted: Monday, Feb 07, 2011 at 22:40
ThreadID: 84197 Views:2432 Replies:3 FollowUps:9
Is it just me or is the site blocking access ?
I can't log in or access my profile or make any changes.
I need to use a visitor profile to access the site ?
I have cleared history, cookies and tried with Explorer, Safari and Mozilla with the same results.
See below....
Server Error in '/' Application.
Object reference not set to an instance of an object.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an object.]
UserBar.Page_Load(Object sender, EventArgs e) +253
System.Web.UI.Control.OnLoad(EventArgs e) +99
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Control.LoadRecursive() +141
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
Version Information: Microsoft .NET Framework Version:2.0.50727.3615; ASP.NET Version:2.0.50727.3618
Reply By: Member - Joe n Mel n kids (FNQ - Monday, Feb 07, 2011 at 22:52
i dont know but i would have thought you would have had to of been a member to be able to have a "profile" ...
I may be wrong, dont know ??
AnswerID: 444586
Follow Up By: justvisitingfornow - Monday, Feb 07, 2011 at 23:02
Yes, had no problems for 6 years now but the last 2 weeks have been getting worse and worse.
I have emailed the EO team but have not had any response.
I have just sent David a Skype message so perhaps he will answer me later.
My problem is I can no longer access my profile so can't change member offers or any other personal information about my business (it is a business profile).
Derek from ABR
ABR-SIDEWINDER
FollowupID: 716727
Follow Up By: Member - Joe n Mel n kids (FNQ - Monday, Feb 07, 2011 at 23:19
oh sorry, you would know a tad more about how it all works than i would....
Cheers Derek
Joe
FollowupID: 716729
Follow Up By: Member - Joe n Mel n kids (FNQ - Monday, Feb 07, 2011 at 23:23
Ummmm i just had this in my face, Derek i think there may be a "hiccup" in the system....... time for a beer
Exception Details: System.Data.SqlClient.SqlException: Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding.
Source Error:
Stack Trace:
[SqlException (0x80131904): Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding.]
System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) +1950890
System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) +4846875
System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj) +194
System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) +2392
System.Data.SqlClient.SqlDataReader.ConsumeMetaData() +33
System.Data.SqlClient.SqlDataReader.get_MetaData() +83
System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) +297
System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async) +954
System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result) +162
System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method) +32
System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method) +141
System.Data.SqlClient.SqlCommand.ExecuteReader() +89
ExplorOz_Master.ContentMgr_getPageDetails() +854
ExplorOz_Master.Page_Init(Object sender, EventArgs e) +444
System.Web.UI.Control.OnInit(EventArgs e) +99
System.Web.UI.UserControl.OnInit(EventArgs e) +77
System.Web.UI.Control.InitRecursive(Control namingContainer) +333
System.Web.UI.Control.InitRecursive(Control namingContainer) +210
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +378
FollowupID: 716730
Reply By: ExplorOz - Monday, Feb 07, 2011 at 23:26
Derek,
Try it now - the error just reported above was me installing a minor change.
David
ExplorOz
Business Member
My Profile  My Blog
AnswerID: 444594
Follow Up By: ABR - SIDEWINDER - Tuesday, Feb 08, 2011 at 07:57
Hi David
Yes all working this morning including 'My Profile'
Thank You
Derek from ABR
FollowupID: 716736
Reply By: Dasher Des - Tuesday, Feb 08, 2011 at 09:25
I also have had issues with the site over the last week. I would open up a thread and it would open for only a few seconds before returning me back to the main forum. It happened last Friday night and again last night. Other times it ahs been fine.
AnswerID: 444620
Follow Up By: ExplorOz - David & Michelle - Tuesday, Feb 08, 2011 at 12:15
Dasher Des,
Now this sounds like it may be a faulty ad in the network - can you try to capture/look at which ads are showing when it is failing and let me know this may help.
David
FollowupID: 716777
Follow Up By: Dasher Des - Tuesday, Feb 08, 2011 at 12:57
Can do David although it appears to be an intermitant occurance.
FollowupID: 716783
Follow Up By: Member - Vin & Lisa - Thursday, Feb 10, 2011 at 02:07
I have also seen a few issues, but seems to be fixed now, except that I am a new member and have (still) been unable to load a profile/rig pic to my profile page. The screen just keeps going dark and failing to upload... can upload other photos to my gallery but not a profile pic.
FollowupID: 717023
Follow Up By: Dasher Des - Thursday, Feb 10, 2011 at 10:01
David, it's a bit strange but it happened again last night. The add that was trying to load was one of your EO adds that opens up on the R/H side of the screen. When it goes back to the forum page, the pictures down load like they should. It seems to only happen on my lappy at home and note at work.
last night I ran a virus scan and I'll see if that fixes anything tonight.
Cheers Alpaca
FollowupID: 717046
Follow Up By: ExplorOz - David & Michelle - Thursday, Feb 10, 2011 at 16:16
Dasher Des,
It may be also day of week based so we should record that it happened on Wednesday. Thanks and let me know.
Vincent & Lisa,
I do not think I have this error reported - have you submitted a feedback for this yet? If you have it may just be sitting in my inbox but if you have not can you please send in a feedback so that we can assign a resource to investigate.
David
FollowupID: 717122
