hitch receiver compatibility
Submitted: Sunday, Feb 06, 2011 at 23:08
ThreadID: 84168 Views:2166 Replies:5 FollowUps:5
I have a Hayman Reese weight distribution hitch. It does not fit into the hitch
receiver on my Rodeo tow bar.
Can I roundoff the edges with an angle grinder to make it fit?
Reply By: Nomadic Navara - Sunday, Feb 06, 2011 at 23:38
nolbrin - that's precisely what everyone else does.
AnswerID: 444466
Follow Up By: nolbrin - Sunday, Feb 06, 2011 at 23:43
Thanks PeterD, Will give it a go.
FollowupID: 716616
Reply By: MP - Monday, Feb 07, 2011 at 08:27
You may also find once it is in there, if you have factory tow bar like mine the hole for the pin is not centred, and you cannot line up the pin.
Mark
AnswerID: 444482
Reply By: MEMBER - Darian, SA - Monday, Feb 07, 2011 at 10:20
Yep - but you may well only need to run a whisker of metal off the 4 corners though - had to do that with my Hayman R 750 WD kit, when fitting it to a Trail Boss towbar (made by Hayman - go figure :-o).
AnswerID: 444491
Follow Up By: Member - Graham H (QLD) - Monday, Feb 07, 2011 at 11:02
Yep same as mine and the Patrol was identical
Just dont let the pin get rusted in like mine did.
Was a nasty job to get it out. Had to drill it back in as far as the hitch bar and shear the ends off by hammering it from inner end.
Then had to drill the whole pin out of the tongue.
Not the most enjoyable job.
FollowupID: 716634
Reply By: River Swaggie - Monday, Feb 07, 2011 at 12:57
and once its in place they work bloody wonder's too...
Up Creek Without A Paddle
AnswerID: 444501
Follow Up By: Ianw - Monday, Feb 07, 2011 at 19:28
That must be some winch hes got !! 120000lbs = >54tonnes
Ian
FollowupID: 716678
Follow Up By: River Swaggie - Tuesday, Feb 08, 2011 at 16:29
Nah mate
It was a 10000lbs 15 year old unit....
FollowupID: 716815
Follow Up By: River Swaggie - Tuesday, Feb 08, 2011 at 16:35
yeah good pick up Ian... lol
FollowupID: 716817
Reply By: nolbrin - Monday, Feb 07, 2011 at 21:24
Thanks fellas,
Job done with grinder. Pin lines up with hole,phew.
AnswerID: 444576
