Tunnel Boots
Submitted: Thursday, Feb 03, 2011 at 16:01
ThreadID: 84084 Views:9209 Replies:8 FollowUps:16
We have recently ordered a Sunland Patriot which has a tunnel boot. I was wondering what is the best way to utilize the space and what type of things are best stored there.
Reply By: Member Boroma 604 - Thursday, Feb 03, 2011 at 16:17
Gooday,
I was quite concerned when we got our first tunnel boot, am on our second and the best invention. I use two long plastic boxes with lids and rollers about 6inches deep and then one about 12inches deep from one side, then another 12inch deep on the other side for bits and pieces, a couple without lids about 6inches deep and 15inches long on the other side. I find this allows the placement of things like Jockey wheel anti flap kit etc to sit in front of them. Was some trial & error before I worked it out. Would not go back to the traditional boot.
Boroma604.
AnswerID: 444035
Follow Up By: Member - Wendy C (NSW) - Thursday, Feb 03, 2011 at 22:40
Hi Boroma 604
Really good ideas - where did you get the plastic boxes in those sizes and on rollers as well?
FollowupID: 716179
Reply By: John and Lynne - Thursday, Feb 03, 2011 at 16:57
We hope you enjoy your Patriot as much as we enjoy ours. We had a tunnel boot in our previous van too, and they are great once you get used to packing them logically.
In the Patriot we use the tunnel boot for things we need to carry but don't necessarily want every day eg spare tools, shadecloth awnings, hobby equipment like fishing and fossicking gear. It is a good place for long items like brooms and poles, buckets, Baby Q or camp oven. Put some padding at the ends so there is not too much movement eg groundsheets.
The floor of the Patriot tunnel boot is slippery so, if you organise things in plastic boxes it is quite easy to pull out the box you need with the pole provided, even from the middle.
The front tool box is ideal for items you need quick and frequent access to such as hoses, wheel chocks, power cord, tools. It also holds out towing gear like sway bars, hith and mirrors while we are camped.
The two boots work very well for us - just watch weight - it is easy to overload them with boys toys if you are watching ball weight!
Enjoy your Patriot! Lynne
AnswerID: 444039
Follow Up By: Member - Wendy C (NSW) - Thursday, Feb 03, 2011 at 22:38
Hi Lynne
Thanks for the info - some really good ideas.
Do you have a generator? We were contemplating puting in generator storage but that takes up part of the tunnel boot and the generator compartment is then sealed off from the rest of the boot. So you then don't actually have a tunnel boot just a long boot accessible from one side and the generator storage box on the other. So we're thinking we could put the generator in the front boot even though it would be harder to get out - we don't actually use it very much.
FollowupID: 716178
Reply By: mike39 - Thursday, Feb 03, 2011 at 20:05
Can't comment on the tunnel boot, but mate down the lane from me has just taken delivery of one. (Patriot)
What a superbly built and fitted out unit, very envious.
No should not say that, very happy with our old 15 footer!
How long delivery, I notice that the Uralla (nsw) Sunland dealer has one in stock now but may not be to your requirement of course.
Happy travels to you when you have it on the road.
mike
AnswerID: 444062
Follow Up By: Member - Wendy C (NSW) - Thursday, Feb 03, 2011 at 22:31
We have just ordered our Patriot and delivery is not until mid May. Meantime we have our Supreme Getaway to detail and get ready to sell. We have had some good trips in it but it is time for the extra space and comfort of the Patriot.
FollowupID: 716177
Reply By: Nev (TAS) - Thursday, Feb 03, 2011 at 21:02
Hi Wendy,
I have a tunnel boot in my new van also. The drivers side has a 900mm locked drawer in it made very snugly. At the end of the draw is a full height divider so nothing from the other side can get through and block or jam the drawer. Anything long goes into either of two lockable pipes under the van, but that is mainly my 1 piece beach rod. All our brooms etc have retractable handles so easily fit in the boot. I hope you have a great time with your top class purchase.
Nev
AnswerID: 444071
Follow Up By: Member - Wendy C (NSW) - Thursday, Feb 03, 2011 at 22:44
Hi Nev
What type of van do you have? The lockable pipes under the van sound good. I was worried about blocking off one end of the tunnel boot for generator storage as long things would then not fit in the boot.
Wendy
FollowupID: 716180
Follow Up By: Nev (TAS) - Friday, Feb 04, 2011 at 06:34
Hi Wendy,
I have an Orion Starline. They advertised on EO so I chased them up and was suitably impressed so I ordered one. I have another hatch for my generator also with a heavy duty slide built into it. I find it easier to lift the genny onto the slide and push it in then just loading it into the hatch.
I have no interest in Orion apart from being a satisfied customer.
Rgds
Nev
FollowupID: 716198
Follow Up By: youngharry52 - Friday, Feb 04, 2011 at 11:58
Hi Wendy,
We have a centrally divided tunnel boot in our van and use the off side for generator storage. Don't forget to vent this locker if leaving fuel in the genny.
Chris
FollowupID: 716241
Follow Up By: Member - Wendy C (NSW) - Sunday, Feb 06, 2011 at 17:03
Hi Chris
Do you have your generator on a slide? - otherwise I thought it might slide around. Also is your tunnel boot evenly divided? In the Patriot iif you have the generator storage on one side of the tunnel boot the other side is quite long and with access then only from one side. I'm not sure if that would be a problem.
Wendy
FollowupID: 716557
Follow Up By: youngharry52 - Tuesday, Feb 08, 2011 at 09:37
Hello Wendy,
No, it's a 2.4 Yamaha, so it was too high for a slide. It has rubber feet ansd is fairly heavy so it hasn't moved yet. I also pack some things around it like small chain saw and fuel containers. the vent is essential though as you can smell the fuel when you open the boot door.
No, it's not evenly divided. The other side is long and is good for longish things like awning anti flap thingies etc and its fairly easy to reach into because I think it's abpout 600mm square. If you wanted to, you could put large plastic bins on small wheels etc to the back....
Chris.
FollowupID: 716754
Follow Up By: Member - Wendy C (NSW) - Tuesday, Feb 08, 2011 at 10:47
Hi Chris
Thanks - that's helpful advice.
Wendy
FollowupID: 716764
Reply By: Gone Bush (WA) - Thursday, Feb 03, 2011 at 22:43
We also have a tunnel boot in our BT.
On the left side I installed a slide out BBQ
Image Could Not Be Found
On the right hand side I installed a large box to carry long, awkward items like aTrail-a-Mate stand.
There's still plenty of room for other stuff including a twin tub washing machine.
AnswerID: 444090
Follow Up By: Member - Wendy C (NSW) - Thursday, Feb 03, 2011 at 22:50
Hi 'Gone Bush'
Thanks for the pics - you look like you have a great set up. Do you have to worry about the bbq splattering on to the van or do the sides of the bbq catch any mess?
Wendy
FollowupID: 716182
Follow Up By: Gone Bush (WA) - Thursday, Feb 03, 2011 at 22:59
Hullo Wendy,
I always cook with the lid down to maximise the heat. When it's like that the smoke etc escapes through a gap at the back of the lid.
That's why I installed it so that it slides out longitudinally and the fumes escape away from the wall. Also why I put it there and not under the awning.
FollowupID: 716186
Follow Up By: Gone Bush (WA) - Thursday, Feb 03, 2011 at 23:05
There might be some more ideas that interest you in my Blog:
GB in a BT
FollowupID: 716187
Follow Up By: Member - Wendy C (NSW) - Thursday, Feb 03, 2011 at 23:08
It looks a really good set up. I'm constantly impressed at the great ideas some people have developed and put in to their vans.
FollowupID: 716189
Reply By: John and Lynne - Friday, Feb 04, 2011 at 10:01
We do not carry a generator - we find that with the large solar panel we have no problem keeping the battery charged even for extended bush camping and we do not have a compressor fridge. (So far we are most impressed with the performance of the large 3 way fridge that came with the Patriot and we tested in in temperatures well over 30C) and we can charge our computer etc via 12 volt power points. The generator just seems to be a lot of weight and another lot of fuel to carry. Some people apparently carry a generator in the front tool box and run it in there - OK if the noise doesn't bother you! We would be reluctant to block off the tunnel boot - it is so useful to access it from both sides. Other people carry a generator in their vehicle.
We considered putting a slide in the boot but, after using the van, decided it was quite unnecessary. A slide takes up space and the Patriot tunnel boot is not particularly high so a slide could restrict what you could fit in. Also, as I said, the lining of the boot is very smooth and slippery so it is easy to pull things out. We don't have boxes with castors either - they also take up space and usually break off anyway, from our experience!
I suggest you wait until you have had a decent shakedown trip and see if you really want a generator or a slide after you work out what you need to carry in your Patriot. Lynne
AnswerID: 444131
Follow Up By: Member - Wendy C (NSW) - Friday, Feb 04, 2011 at 10:33
Thanks Lynne - all sounds like good advice. I think after we pick up the Patriot in mid May we will have a week not too far from Sunland in case anything needs fixing. We're from Sydney so it's a long way to go back to Sunland if anything needs doing. What options did you take up with your van? Do you have an annexe? - we're contemplating getting one for extended stays or for when we have our little grandkids with us. Sunland don't do them so we will need to order one independently.
Wendy
FollowupID: 716224
Reply By: John and Lynne - Friday, Feb 04, 2011 at 12:12
Hi Wendy
We do not have a full annex and did not have one on our previous van. We have extra shadecloth awnings that we can use on the driver's side of the van or add to the roll out awning for extra shade and privacy when needed. These are handy and we had them made quite cheaply by a canvas place.
We have never needed a full annex but I can see one could be useful for the grandkids - ours are still a bit young to take but the time may come! If yours are old enough they may enjoy a small tent which could be a cheaper and lighter option!
If you mostly intend to tour in your Patriot, as against staying in one place for a lengthy time, you will probably not want to go to the trouble of setting up an annex. Again, this is something you can work out as you go!
You could try posting a question about the usefulness of annexes and good quality manufacturers in your area on this forum or on Caravaners Forum and get suggestions from people who use them. Good luck! Lynne
AnswerID: 444141
Follow Up By: John and Lynne - Friday, Feb 04, 2011 at 13:05
Sorry Wendy, I forgot the rest of your question. The only extras we had fitted were a 170 watt solar panel (which may be standard now) instead of the original 80 watt one. We also had wiring installed in case we ever want to add another panel. We also had another water tank installed and chose a 4 burner gas stove instead of the 3 gas and 1 electric burner model. Otherwise we left the van as standard. We probably should have had a gas connection for the new Baby Q, which is on our next shopping list. This will be an after sale addition now! We did not install the optional gas heater but this could be worthwhile if touring in winter - we may live to regret that decision as we hear good reports of the gas heaters and it is hard to avoid some cold weather! Lynne
FollowupID: 716252
Reply By: Member - Wendy C (NSW) - Sunday, Feb 06, 2011 at 17:12
Hi Lynn
The 80w is still the size of solar panel that is standard on the Patriot and there is an option to upgrade to 135w. I'm not sure what the 80w would do or even the $735 upgrade to the 135w. The 170 watt doesn't seem to be listed as an option. What can you do with yours?
Wendy
AnswerID: 444422
Follow Up By: Member - Wendy C (NSW) - Sunday, Feb 06, 2011 at 17:22
Hi again
The gas heater is expensive but would be good. The reverse cycle air con would be fine unless you were free camping. I've seen portable camping heaters but I think they could be dangerous to use in a caravan.
We've included the external gas bayonet - better than carrying an extra bas bottle for the bbq.
What colour scheme did you choose?
Wendy
FollowupID: 716561
